1 - 14 of 14 Posts
Hello guys, I'm a tall guy (6'5") that has a 2016 650 and decided to buy a D4114ST Givi windshield after I had buffeting and noise problems with the stock windshield. I partially resolved them with the Givi windshield, but as soon as I get to higher speeds ( 70 - 80 km/h) the noise starts killing my ears again. If I lower my head just a little bit, the noise disappears and I can hear my bike's engine sound as well.
So my question is: do you guys think I'll have problems with aerodynamics or anything like that if I raise my D4114ST Givi windshield over the stock limit? Pic related (I got it from another user in the forum that did the same thing with stock windscreen).
I'm a little scared considering the Givi windscreen has a speed limit of 130 km/h written on it, so I wouldn't want to mess anything up by raising it. By rising it just a tiny bit like that I'm sure I'll be in the bubble of air.
I'm going on a trip with my wife on the bike soon, and I'd like to enjoy it without my ears dying and if possible without having to wear earplugs, that's why I'd like to do this.
I know what you mean, but I'm not sure if that is safe or not. It feels ok, doesn't it? I've had it that high before by mistake and it felt tight.
Have you considered a windscreen flip / extender? Like the MRA X-screen? I used one (a different one) on my last bike and really liked it.
https://www.bikehps.com/acatalog/MRA_X-creen_Motorcycle_Screen_Flip_Spoiler_Air_Deflector.html
I have considered it, but I'd like to know if I'll be fine with raising the windshield I already have before buying something else, I'd like to save the 60 bucks if I can :grin2:
If you need a couple of more inches of height I would opt for the "extender". I think doing it the way you suggest might weaken the shield (not as much support at the mounting point). Cracking a $117 shield would really irritate me.
I just installed the same shield on my 2015 and I haven't tested it yet but with the shield all the way down I'm just barely looking over the top (it's right at eye level). It might just be a bit tall for my 5' 9" body. We'll see......
I wonder if there's a safe way to test this... should I be looking for too much bending of the windshield, or what?
These go for like 65€ in Italy by the way :grin2:
If you look at the mount point as a "lever arm" you can see how the stress will be re-distributed from an even amount on both screw holes to more on the bottom and less on the top. Don't know for sure how the average backyard mechanic could measure that.
I actually was a bit concerned when I saw Givi's warning about speed limited to 130 KPM. That's only 80 MPH and I get up over that easily passing a vehicle. I'll have to keep an eye out for stress cracks.
I'm sure getting to 130km/h for short periods of time won't be a problem for the screen.
Gonna try raising it over the stock limit today and see how it goes, I thought I'd find someone else that did it before me here but no luck. I'll let you guys know how it goes.
EDIT: I did it, sound is way better and no problems whatsoever, let's hope it will stay the same in the long run.
I just did a 130 mile test ride with the new screen. First half in the "down" position and then raised it about 1/3 and went about 20 miles before deciding the wind wasn't any better and I don't like looking through the screen. Dropped it down for the rest of the ride and that's where it will stay.
Much less wind buffeting with this screen vice the OEM one. Not as calm as being behind a batwing with a medium shield but I would recommend one for the Versys.
How tall are you? And are you still looking through the screen in the low pos?
I'm 5'9" and after a couple of hours of riding my posture is horrible. I've got a back belt now and it helps me with the posture. I just barely see over the top of the shield (in the low position) and it works for now. The first time riding in the rain will tell if the low position works.
After checking it out, you can always remove an inch or so from the top....
1 - 14 of 14 Posts
