1 - 3 of 3 Posts
I removed my forks today to take them in for new seals (HOPEFULLY under warranty!) tomorrow.
Using my SERVICE MANUAL I ran into a road-block at the point where you remove the fender, as, no matter what I did at THAT point it wouldn't come thru the forks as the "bracket" for the ABS speed sensor makes it TOO wide, and it can't be rotated 90 degrees w/ the wheel still attached.
Removed the wheel, then the fender came out fine.
Just a "heads-up"....
The 2015 front fender can also be removed by first removing the front cowling (four bolts), if you don't want to take off the wheel.
1 - 3 of 3 Posts
