1 - 9 of 9 Posts
Been following tire threads, don't think this has been mentioned. But my 2013 has a bit over 1,500 miles and the center rear has worn flat, I would normally guess over inflated, but if anything I have been running less air. There is a distinct line on both sides of the tire, where the wear ends. I haven't noticed any issues with the cornering, but I don't lean it over anywhere close to dragging the pegs.
You're not leaning it over often enough.
Seriously, 1500 miles is pretty quick to go through a tire (my stock tires lasted around 10000 miles and still had some life left in them when I replaced them, I replaced them because they started to get slippery in the rain), although It's pretty normal for the center to wear more than the sides if you ride a lot of straight roads. Most modern tires are made with a harder compound in the center to resist wear while still giving good traction in the turns.
An example, 90% of my riding is done on two lane curvy roads. My commute is all two lane with a lot of turns, I very seldom ride interstate. My rear tire is wearing less in the center and most about half way between the center line and the outside edges on the tread. I figure I'm probably using that part of the tread a little more than it was designed to be used.
If the center has worn flat I would suspect it's from under inflation causing the tire to compress and flatten the center section, increase friction temperatures and thus accelerate wear. But then, I'm not a physicist or tire wear expert. Just seems to make sense to me.
I suppose you could even things out by riding tight left hand circles for a few days followed by tight right hand circles for a few more days. At least the wear would be even. :wink2:
I'd go w/ 'underinflated' too, plus just riding in a straight line.
FWIW - I run 36F and 42R (psi), and HAVE for OVER 100,000 miles on three Versys alone.
Lower inflation will definitely wear a tire faster than over inflation. However, lower pressure (within reason) will give greater traction/grip. I run the recommended 32 psi front, 36 psi rear pressure because that seems to be the sweet spot for handling and I want to have fun on motorcycles, not win some imaginary mileage/wear contest. Sure, I could probably extend the life of my tires by a few thousand km if I boosted pressure, but I don't really give a damn.
For the same reason I really don't care what fuel mileage I, or anybody else gets on the V. If I were concerned about economy to that extent I would not even ride a motorcycle. My car gets better mileage, but so what? Big effing deal, it costs less to ride slow but where is the fun in that? >:)
Inflation (or under-inflation) has more to do with your tire wear, than your local road topology... Under-inflation creates a number of issues, and the only time you should be running (a little) lean is if you know you're spending the day in the canyon/mountain twisties, and you feel you need the slight traction bump it gives you...
I typically run 33-34 front, 36-37 rear, depending on what I'm carrying... With PRs (on prior bikes) it's given me up to 12k solid... The stockers on the Versys were still fine at 4k, at those pressures, but I swapped 'em out (simply because I didn't like 'em)...
I would guess your running under inflated as others have suggested. I run my rear a few pounds over what it calls for, specifically for wear, but make sure your at least running what they call for. Check your gauge against a different one. I have on gauge that reads a consistent 4lbs les than actual air pressure, and it's not a cheap gauge either.
1 - 9 of 9 Posts
