Somebody tried hyperpro spring?does it eliminates wavy feel in corners? I know some are using r1 shocks but are there some others shocks maybe from versys 1000 or some other bikes? And what's the difference in length or else between rear shocks 1st and 2nd Gen of versys? Thx
...And what's the difference in length or else between rear shocks 1st and 2nd Gen of versys? Thx....
None. Here're pics of my '09 (Gen 1) and my '15 (Gen 3). They are BOTH wearing the SAME R1 shock, which I removed from the '09 when I got the '15.
R1shock1 by Ed Copeman, on Flickr
IMG_0634 by Ed Copeman, on Flickr
Have you tried adjusting the rebound damping to reduce the "wavy feel"?
Yes.. I set sag to my weight but the rear is still too stiff for me (80kg)...I'm missing the rebound damping on the rear a lot...can a hyperpro spring help? I think to change the shock from gen 2..will it pass? Or what about shock from liter versys? Don't want to change for r1 so far..
2015 650 Versys LT ABS
Yeaaahh, with 80kg the rear needs to get sprunk to your weight and riding preferences. Before going global, I would check your local suspension tuners, I found my on track days or even motocross days. Chat with them, below are the sag number I use from PDR Suspension Performance.
2015 650 Versys
Sag
Forks 33mm
150mm travel
22% of travel = 33mm
current sag 28 (fully suited up)
fully seated clockwise
Rear Schock 43mm
145mm
33% of travel = 43mm
current sag 36mm (fully suited up)
preload is fully seated counterclockwise
2015 650 Versys
Sag
Forks 33mm
150mm travel
Rear Schock 43mm
145mm
My Suspension Guy Dave Moss has a question:
"It will be mostly due to the front forks. Please send a picture of both tires. "
My sag
Front 35
Rear 33
Dont think it's due to the front forks.. My tyres are brand new a week old.. Probably 300km so far... Your sag is too weak at the rear I think, the bike sits like chopper
