1 - 14 of 14 Posts
First time posting, long time lurking. I'm in the process of rebuilding an 08 V I inherited recently and its almost done (pics coming soon). I've done all the work myself from end to end, except tire change. I figured while I'm having the tires changed, I'll ask the mechanic to change both sprockets and change the chain as well.
Today, I noticed when I slam on the rear brakes, I hear a banging noise. After inspection I noticed its the rear caliper bracket which the 2 rear caliper bolts attach to. The bracket moves front to back, but not side to side. The caliper bolts are tight per spec and caliper does not seem to be the culprit. I don't remember hearing this prior to visiting this mechanic. Before I call him can you direct me please. Is it a spacer, pin or anything that he could have missed. Thanks in advance.
Papa K
Papa K
the rear caliper bracket engages an anti-rotation tab on the swingarm when the rear wheel is properly installed. your "mechanic" apparently overlooked this part of the install. the bike can not be ridden in this condition, so have him pick it up, fix it, then deliver it back.
Guys, I need further help please. I don't trust this mechanic and as I've done all the work on my bike, I want resolve this issue myself. I took the rear wheel off to inspect the anti rotation for the rear caliper. I see the square tab on the that the bracket fits into, but there is play when I hold up the bracket against it, just as there was play with the bracket when the wheel was installed. What am I missing here? The slot seems a bit larger than the tab and there is 1/8 to 1/4 movement!
Thank you.
Papa K
the matching mating surfaces have an approximate 2mm taper and are designed to lock together when assembled, virtually no movement when done properly. you're saying that your observed movement is 3X the taper, no way without something being messed up.
Resolved.
It was not assembled properly. Actually nothing was IMO. I removed the wheel and chain and reassembled using common sense and it went back together like ying yang. What threw me off was the 2mm taper because when I disassembled I put up the bracket slot against the tab and I had movement. When I zipped it all up, it was all fine.
Lesson learned......Learn to change my tires myself and never trust my bike to any mechanic. Its about the only thing I haven't done yet.
Thank you very much JDrocks & invader. Best wishes for the New Year.
Papa K
"Lesson learned......Learn to change my tires myself and never trust my bike to any mechanic. It's about the only thing I haven't done yet."
There are a lot of incompetent mechanics, often due to pressure from the boss to get the work done as quickly as possible. I do all my own mechanical work but I don't have a tire changer or balancing stand. The solution for me is to remove the wheels and take them to a person that I trust to properly mount the tire. Finding that person may be a challenge. I use a small local two-partner business: it is better to have the boss do the work than a pressed-for-time hired hand.
:thanx:Thanks for posting, the hardest part at times is the first attempt at doing the wrenching yourself. If you do it one step at a time, make notes take pictures, soon it is easy!!
FYI there are PDF manuals for MK-1,MK-2,MK-3 and also the V1000 on this forum. As we progress , those that have taken the time to take pictures and add description of How To do it, those threads will be copied to the How To Forum, the original thread will continue for further input/ questions. Some of the existing threads in that forum were more of a discussion with excellent pictures, some photos have been lost due to the change over from the original back in 2008.
:welcome:
...Learn to change my tires myself and never trust my bike to any mechanic....
The FIRST (and only) time I used a bike-shop (one that sold Bandits, BTW) to change a tire was on my Suzuki Bandit 1200. They called to say the tire was IN, so I made an appointment, removed the wheel, drove in (an hour), handed the wheel to the mechanic and said "You know which way the wheel rotates?" as the tire had directional arrows on it, to which he scoffed "Of-BLOODY-course I do!"
I went to their lounge, had a coffee, read a magazine, then they called my name saying that it was ready.
Picked up the wheel, looked at the arrows - they'd mounted it backwards!!! :mad:I made them remove it and do it right, but then I started doing my own tires.:censored:
:thumb: - :thumb:
:thumb: - :thumb:
Do you have a recommended method? I spend about $100 usd on tire changes each year.
I have good luck with the No-Mar bar and a fleabay bead breaker base.
I think I've got about two bills tied up in the tools but receive a regular supply of pizza for their use by other riders.
I use a 'bead-breaker' I bought from Whitehorse Gear, 3 long tire irons, LOTS of lube (either tire-lube I buy at a tire shop, or WD40), and ALWAYS HAVE THE TIRES HOT (sit them in the sun!).
When installing the new ones I use zip-ties, and the tires go on EASILY!!!
Here's a pic including the tools:
1 - 14 of 14 Posts
