My V650 2015 has been eating brake pads (edit: ~2500 miles per set of pads). The first time I didn't catch it in time and it ate through my rotor. The second time I caught it in time and discovered a caliper grease boot on one side had worn through and was dry, while the other side had very little grease (the two rods it slides on). I rebuilt the caliper from ground up, took everything apart, cleaned, replaced piston seals, new grease boots packed with grease, new pads, etc.. Piston was in perfect condition. All looked to be perfect. Now brakes are working fine, however, I noticed the rotor is quite warm/hot to the touch after riding. There is no discoloration, but it's hot. I am not using rear brake excessively. What's strange is the front rotors are cold, even though I'm using the front brake all the time.
I'm thinking for some reason the piston is not retracting, even with brand new seals, but I have no idea why.
Anyone else encountered this and identified a solution? After a complete rebuild I can't think of anything else to do.
