I have Versys 650 2012 that have rear ABS brake error. My front brake is working fine. I tried one shop and he told me that i have faulty abs pump. He quoted me around 20,000 Baht (Thailand). I went to some kawasaki shop in Bangkok, but they won't replace ABS pump if I will buy second hand.
Is there anyone who have the same experience? Buy second hand from Ebay and went to reputable shop to install. Can you recommend some shop here in Bangkok Thailand will do the job.
Thank you in Advance.
Discussion Starter #2
Best solution for Cleaning and tubricant chain!!!
I tried to search as much I can what would be the best solution for cleaning and lubricant Chain. I just change new set of chain and Sprocket (15/45). I'm about to chain and lubricate my chain. Any best and cheapest solution to clean and lubricate chain is appreciate.
Thank you in advance.
Can you get a second opinion on the fault code from another shop. Did Kawasaki Bangkok actual verified ABS pump module problem.
Thank you fastoman, I will try another kawa shop first. One shop did told me that they won't install from second ABS.
