Actually this subject is quite active : http://www.kawasakiversys.com/forums/showthread.php?t=16774&page=12Ok, I know this is an old thread, but curious of any result in this problem... I am currently dealing with the exact same thing, down to every detail.... Failed headlight, starter clunk when turning the bike off, etc. My stator failed in November of last year, which was proceeded by a headlight failure.... I replaced the stator, and the r/r . Now, Tuesday afternoon, I pulled up behind a car at a stop light, and noticed my headlight wasn't working. Got home and started running some tests... The stator shows passing on everything except the coil/ohm test, which my tester doesn't read below .4 ohms, and the manual gives a .0125-.25 service limit.... I am assuming it is still good since the wattage reading at 4000rpm's is dead on, and not showing any readings on the dead short test.... The r/r is not reading as it should in the test, but the old one I took off the first time around is... I tried it for testing purposes, but still only getting 12.2 volts at the battery around 4000rpm's wich is way low... Battery is good... Will hold a continuous 12.6 volts when not running.... I am lost here... I am afraid that whatever caused the first failure is at it again, and I need to figure out what is going on....
Hoodlum
However to save you some time, a very simple test to start with is to hook up a charger or other reliable 12VDC source to run your bike.A very accurate test to see if you have shorted turns, is to measure the three phase voltage at idle with the regulator disconnected. Measure A to B; B to C; C to A , last measure A to ground, B to ground and C to ground.
Best place is to disconnect the plug from the alternator output near the throttle position sensor, only drawback is you need very small probes on your meter, plus you don`t want to short these out because you could have 15 to 20 amp available. The second place which is easier as to size of probes is the plug at the regulator, measuring here the only drawback is the headlight relay circuit is partially active if you have a grounded turn on the stator. In either location you are looking for 36 to 48 volts AC, what is important is to have the bike warmed up and at idle, also you are looking for the exact same voltage on all three phases.
Word of warning, if using the regulator plug location for measurement, the voltage to ground may be a bit weird as the headlight relay uses a half wave rectification referenced to ground to pull in the relay on only 1 phase, this connection is in the harness , after the TPS plug, but before the regulator plug. Most important is the phase to phase voltages.
FYI the regulator plug has three black wires entering I think on the bottom of the plug, that is the test point if you aren't comfortable with the plug near TPS, this is also shown in the manual under regulator testing.
