1 - 15 of 15 Posts
My 08 makes an odd rattling noise from the drivetrain when I'm on the throttle. Clutch in, it goes away. The noise also goes away when there is no tension on the chain: only occurring during acceleration.
It sounds similar to a Ducati dry clutch (I'm using synthetic Shell 5W-40). There is no clutch slippage and everything works perfectly. The chain and sprockets have 17K well oiled miles on them: getting to the end of their life for sure, but showing no signs of excessive wear on the sprocket teeth.
The bike has made this noise for as long as I've owned it (2 yrs) with no ill effects that I can tell.
Has anyone run into this before?
Does it sound like this....
If so i tightened up the chain and that helped some.
As mentioned, mine made the sound when the chain was to slack. When on the throttle the chain would hit the plastic guard on top of the swing arm.
If you pull the clutch and let the engine slow down to idle, is the noise still there
Louder, faster, same, none
If it still there, something that is roling at the speed of bike is responsible
If gone or change, problem from the engine or the tranny
My 2 cents
LOP
the rear hub has rubber dampers (cush drive) between the wheel and the rear sprocket but usually the bike has to be pretty old for them to wear out and cause noise.. something to check...it might be a good idea to remove the wheel and check the bearings too.
The only gripe I have with my '09 versys is the excessive gear whine
It has been that way since new and in all gears at all speeds.
If I didn't wear ear plugs it would really detract from an otherwise
excellent ride
Probably chain/sprocket wear although usually this is also present when coasting. I'd put the bike up on a pit stand and rotate the rear wheel to check for changes in resistance, binding, chain slack, etc..
If your chain is aligned OK and has 3.0mm to 3.5mm of slack you need to replace the sprockets and chain, noises will slowly increase over time.
Suggest OEM front sprocket and after market rear sprocket with side beveled gears in stock sizes. The OEM front sprocket has a rubber noise/vibration damper the aftermarket front sprockets don't have. Xring chains will usually outlast Oring chains but cost more. This is an easy DIY project but requires the purchase of a chain tool for ~$60. You also need a metric socket set with a 26mm socket. Lots of videos on youtube on how to do this.
I had this when my stock chain and sprockets needed changing. It wasn't a tightness issue (I played with the adjusters a *lot* trying to make it go away).
New chain and sprockets fixed the issue.
Mine does the same. Chain is within spec and sprockets are fine. Only anoying when riding close to a higheay barriers. I just ignore it.
Sent from my DROID BIONIC using Motorcycle.com Free App
Check to make sure the chain is aligned. My KLR rattled and I checked the chain and it was maybe out 2 turns out of adjustment. Made it quieter and the chain will no doubt last longer too. I use a alignment gauge for this and it's faster and easier than a tape or string. And if it doesn't solve the noise you're still better off.
1 - 15 of 15 Posts
