1 - 20 of 42 Posts
Hi
I added gas twice today to the V (before and after a glorious ride inthe sun on the "Sea to Sky" highway).
The first time I got off the bike, removed my helmet & gloves, added the gas and geared up again.
The second time I sat on the bike, took off my gloves (only) swiped the credit card on the pump, filled the tank, closed the cap, put on the gloves and headed home - much simpler.
BUT afterward I worried - what IF something went wrong - e.g. a spark cause the gas to ignite while I was sitting on the bike. I would have had great difficulty geting off the bike (if the tank hadn't exploded in my face).
Am I being paranoid?
Do you sit on the bike while gassing it up, or do you always get off?
Cheers
Bigaussie
I always get off when I fill up, it does a couple things, it affords you the opportunity to strech your body and it gives you a chance to give the bike a quick look over as there could have been as much 250 miles since you last got off.
Just my thoughts...
Cheers
I always get off for several reasons:
1) I grab a paper towel before I start fueling so that (in the unlikely event) that I spill a little... or even just a few drops spit out... I can get it off tank immediately!
2) A quick visual inspection of the bike & gear.
3) A few deep knee bends for my aging legs (sometimes cleverly disguised as a quick visual inspection of the bike). ;)
4) While I really don’t think it’s ever going to happen, if it ever did catch fire; I want to be running for a fire extinguisher to save the bike, not running for my life!
Whenever I see someone fueling from the saddle I think to myself; Well aren’t you Mr. Cool - You stupid ass!
I get off the bike, get a towel, wipe the nozzle of the pump (so no crap gets in the tank, and use the same towel to catch drips. I don't pay at the pump and usually am out on commutes/ short rides, but it is good to stretch legs and also check the V after paying up.
Get off the bike and refuel. Leather gears are good source for static current and can cause fire! Always get down for your own safety.
:cheers:
That is what I thought AFTER I did it.
I was less than 1 km from home so the stretch / inspection / etc was able to wait that last 60 seconds.
I will take all your advise from now. :thanx:
Cheers
How do you get static current while sitting on the bike? I've heard that before with gas cans that are in the trunk of a car...that is usually carpeted.
The stretching is a good idea but if you're just commuting then why get off if you don't have to?
I ALWAYS gas up sitting on the bike so I can FILL it! :goodidea:
Having said that, I NEVER fill it up UNLESS I'll be riding at least 10 miles so I won't get the gas expanding from engine heat and leaking. (Basically I fill at the start of a ride.) :thanx:
Yes you are paranoid:D
I always fill up sitting on the bike and no explosions in 30 years!
Mainly because like others mention I like to get it filled to the right to the top, plus its a lot less hassle than getting off.
Some times I take my helmet off and make a few cell phone calls as well. BTW, its an urban myth that cell phones can cause an explosion at a gas station. But, peace of mind is a good thing, so keep doing what makes you comfortable and I'll do the same.
Machog
Vehicles can generate a substantial static charge while they’re moving and can hold the potential because they’re isolated from the ground on rubber tires, therefore it’s not a real good idea to make the first point of contact to ground with a gas nozzle.
Thanks Hardware for the explaination on the static current.:thanx:
End of the day, its your call gentlemen. Gas it which everway you feel is good for you. Me will always get down, and fill the tank with the bike on side stand.
:cheers:
I like to stay on the bike but only while smoking and talking on my cell. However I do dismount when I feel like slamming a tallboy before my ride.
Administrator
Well every day I learn something new. Today I learned that my front tire made by Dunlop is made out of conductive compound and the back is also Dunlop and is non conductive, both OEM for the Versys.I tested the side wall and tire tread as well as going from the metal wheel to the tread surface using a 500 volt megger.So some tires are conductive, containing carbon black which is a UV inhibitor.
If you ever see a video of trucks coming in contact with power lines and the resulting tires catching on fire, that is why.:eek:fftopic:
:thumb: weldone onewizard.
Very interesting facts..:interesting:
:cheers:
Yep, I stay on the bike and I don't take my gloves off. I'm in and gone in very short order. Almost 30 years, a few hundred thousand miles, and no issues.
Machog
if you try using your batphone on a petrol forecourt in the UK the pretend "'elf & saftey" twonks will be on your case pronto. I'd agree its an urban myth.... a far more likely explanantion is that some of the early digital fuel dispensing systems have a problem from RFI. there shouldn't be many of those left, as all applainces have to pass the low voltage standards.. that means testign against emitting RFI and against system failure from enternal RFI.... its been a requirement for many many years, possibly 15..20 years
A friend of mine gassed up sitting on the bike when we were 100 miles away from home. He dumped gas in his lap, and we were lucky to be near a truck stop where he could get a shower and run his clothes through a washer and dryer.
And that's why I ALWAYS get off to fuel.
1 - 20 of 42 Posts
