G'day from Adelaide, South Australia!
I picked up a 2017 Versys 650L just before Christmas. It's my first road bike, having only really spent time on chook chasers before, and I'm loving it! What a great machine.
One of my jobs was to mount a Quad Lock charger to it somewhere. Thought I'd share my experience here and contribute my brick to the wall.
I'd looked at the options – stem, mirror, handlebar – and didn't love how it'd look with any of them, so decided to grab a GPS bar so the phone could be above the instrument cluster, then use the Quad Lock handlebar mount to attach it to that. Grabbed a half-reasonable-looking GPS mount bar from AliExpress and sat by the letterbox waiting for my packages.
I haven't got my head completely around what outputs the factory accessory relay kit enables, but I've installed it (a whole $24 from my local Kwaka dealer) and picked up the power feed from the spare bullet connectors behind the instrument cluster. The overpriced Quad Lock 12V-5V converter sits in their cable tied up out of the way. I cut the factory ring terminals and crimped bullet connectors and shortened the cable – they give you enough length to run it all the way back to the battery. The Quad Lock converter has voltage sensing electronics in it, but I leave it switched to "ON" given the power feed is switched off the ignition.
The GPS bar comes with brackets that fit in the triangle cutouts in the windscreen bracket. Mine mustn't have been inspected at QC – they forgot to tap the holes! No trouble, a M6 tap and 5 minutes later and it was sorted.
I mounted the handle bar mount on the bar, removed the extension arm and then fitted their weatherproof wireless charging head. Pretty happy with the finished product!
Hope this is of some use to others down the track.
Cheers,
Andrew.
Cheers,
Andrew.
