1 - 11 of 11 Posts
Hi, I want to ask your opinions or if something like this has happend to you?
I know the Versys have a strong sound when you gear up from first gear to second. I manage to make a smooth transition preloading the gear and then passing it to the next gear. But around a month ago when I'm doing High revs and pass from 1st to 2nd sometimes the gear stays on Neutral and when I want to put second it feels like is going to break like "grrrrrrrrr", I verified the clutch and is fully working, I also have been fully conscious when doing this transition to see if its mee but sometimes I have to stop to put it on second gear when thise happen.
I'm using the correct oil (10W40 Motul Api SL with MA adhitive). My versys is model 2012 with 10,200 Kms.
Thanks, Invader,
I believe is not that because a week ago we lube the clutch cable, adjust and checked the pivot peg, checked the distance from the clucth and the chain tension and all that is ok. I took it to the Kawasaki dealer and checked all together and told them about the issue.
I think I will try with trying to modify the shift lever high, adjust clutch for more travel space and also will try with some motul 7100 sinthetic oil to see if the problem disappears.
Would like to hear more opinions.
I have the Motul 5100 4t, I have use it since the first oil change at 1000 km and then change it again at 8,700 km in the odometer. So I have been using it for about 1,500km since last oil change. The problem started before last oil change, but is more pronounce now.
You do need to shift firmly for a clean shift. Try shifting up harder (within reason), this should help. Good luck. One of my friends stated this to me years ago by saying "Of course you hit neutral, you shift like a P***Y!"
I did a few things, I lube everything around the shift pedal (all pivots), adjust the clutch and changing the gear more firmly. Also adjust a little the travel for the shift pedal so its a little shorter.
Now is a lot smoother and the problem only happens 1 more time since I post this.
I hope the problem was me and not the bike, I can fix myself easier and cheaper than a gearbox. :)
Thanks for all your comments. I will post again if anything happens.
Good advice :thumb:
Its a good idea too loosen the foot pedal (6mm L allen wrench) so you can squeeze grease into the shifter pivot . . . . You will notice a big improvement shifting over squirting lube in the joints etc.
False neutrals happen on many bikes, some are just more sensible to it then others. Just make sure to shift like you mean it :) On a previous bike it happened that for example when I wanted to shift from 2nd to 3rd I'd stay in 2nd. The shift pedal was too low, so even when I lowered my foot to shift, boot wasn't completely releasing the pressure off the pedal so it couldn't reset to grab the next gear.
The shifter footrest pivot is the problem . . . Bad design . . . Should have rubber seals and a grease fitting. Metal against metal causes it to bind up . . . Grease will eliminate shifting issues . . . Will shift like butter.
1 - 11 of 11 Posts
