Dear all
I will be adding some stuff to my Versys (USB lead and heated grips) and from all the information I could dig up it seems that the two power leads at the front of the bike will do that for me. If I am correct there is a white terminal that has a dummy connector (getting power from the relay that I am waiting to install) with no wires and another set of two leads that are covered in a transparent green tube just behind the headlight. I am sorry that I don't have any pictures (actually I have seen the green tube terminals in a video on the net and you need to take the headlight off to get a picture of that). I will try to post a picture from the white terminal however, later on.
My question is, do you know what kind of pins go into the white terminal? There an no pins in the dummy connector, just the waterproof caps on the back and the connector itself. I took it out and I can only tell that I need male ones. I guess if I got the original Kawasaki USB charger it would have the needed plug on but I am definitely not going to be robbed for a USB charger...
Thanks in advance
Does it differ by year?
I dimly remember bullet connectors when I put the cheapo ebay USB farkle and cheapo Kawi relay on my 2016
Dynamite farkle, by the way. Use it daily. Super handy to have.
Umm, I did not use that connector, could not measure any voltage with key on. I did NOT start the bike to see if voltage was present.
I installed the relay and connected it to the other (separate) bullet connectors. Have not used this connector. The white connector that is pictured is not a 'bullet' connector.
X300 / V650 the same ?
I can only comment on the V650, however Kawasaki is known for copying circuits . On the MK-3 650, installing the relay, energizes the connector as shown used for the fog lights, it also has bullet connectors in the same location for powering heated grips etc. on the 650 the current rating was 5 amp fuse.
Just looked up the owners manual , wish we had the PDF of the service manual, as there is some conflicting data. Page 71 &72 explain 2 locations, one for fog lights rated @ 1.2 amp and a second location shown as A which will need to be identified by a X300 owner as the photo is hard to describe as to location, could be around the ignition key?? Total aux. current is 5 amp fuse as stated page 72. I am sure the service manual ( PDF )would explain more as to connectors, which I don't have access to.:eek:
On my Versys 1000 thats where the gear indicator plugs in. But the 1000 does not need the relay like the smaller V's do.....
First of all, thanks for the replies.
They have provided me with some 'keywords' that I had not thought of and by doing some (intensive) searching on google I came up with these Sumitomo MT090 connectors.
The white connector is not powered when you turn the bike on (or start the engine). I used a multimeter and I couldn't detect any voltage there. From what I've read, it only gets power when the relay is installed. The same should hold for the bullet connectors that are hidden well under the front cover and headlight. I also took a look at the manual and the section is indeed very confusing. The "A" connector is definitely the white one (side and top views). There seems to be no picture for the other connector since it would be impossible to show it without stripping all the plastic covers and this seems to go into Service Manual territory. But yes, it seems there are two different connectors.
Thanks anyway
Thanks anyway
I assumed you already installed the relay, on the 650 it was a extra, on the V1000 the relay is included, I assume you need to add the relay for the X300. No mention of this in the owners manual.
