I want to add a power outlet to my 09 Versys. Should I and why would I have to install a relay with the power port?
If I were going to add only one I'd:
Use a fused connection to the battery.
If I needed more than one I'd"
Use one of these or similar
they can be purchased with a combinations of switched (via relay) and un-switched
circuits
When you're not going to use the power outlet for chariging the battery (let alone jump start leads!), you can just wire them up in parallel to the position lights.
