1 - 5 of 5 Posts
Hey folks. Put on a power commander last night and the bike runs great. I am having an issue though where the FI light is staying on. Any body see this before?
I don't know anything about the power commander but I know how to get the FI light on!
I am currently working on a cruise control and it uses vacuum hookup, I had a vacuum leak. If it leaks enough or you unplug the switch at the end of the vacuum line (Inlet Air Pressure sensor) it will throw a FI light.
Don't ask how I know.
I have a PC III and I had no issues with the FI light coming on. I would double check all the electrical connections and make sure the inline plug is plugged all the way in. Next I would check to see if anything got knocked loosed, like a vacuum line as versys_guy stated above.
I also didn't have a FI problem with the PCIII. Don't be afraid to call PC if your connections prove to be good.
Stupid me . . .
You know what fellow's. I forgot the plug that goes into the air box on the right.
Works fine! Thanks for making me go back and check myself. :eek:
1 - 5 of 5 Posts
