Use the type of patch that has the long rubber stem as part of the patch. Dismount tire and rough up around the hole add glue and push the stem on the patch through the hole from the inside and press the patch into place with a roller wheel. That is the best, permanent repair as the rubber stem vulcanizes to the hole and fills it while the patch seals from the inside. A rope plug will require you to enlarge the puncture hole as they do not fit in very small holes.
