1 - 12 of 12 Posts
Hey guys.
I bought the PIAA 500/600 horn system, received it from Amazon today. Took the fairings apart and got down to installing it, then quickly figured out I was in way over my head. :dgi:
You see I'm not very mechanically skilled (zero skill) and have even less skill with electrical work. My garage doesn't look like an ACE hardware and I don't have spare do-hickies and parts lying around.
Can you guys give me some help/suggestions on where and how you installed both horn units? I actually have the wiring figured out, just need to get some splice connectors from my work. I just can't figure out how to mount them... what bits and pieces I need to make it all work.
Any help you can provide is hugely appreciated. This stock horn is just not safe for getting distracted drivers attention. :(
Thanks from the bottom of my heart. :eek:
Not sure what you have done but there is at least two threads on this subject on this forum.
I installed both right at the same stop the stock horn was but welded up a bracket because I am a steel worker, welder, you could say.
Other guys put the second horn where ever they could find a spot, or bolt!
Wiring is simple and in the package, just like hooking up speaker, good luck! Its very easy! Don't over think it! :thumb:
Used the same location as Capn Kirk describes here, was the easiest position to mount it in with (almost) zero modifications -
These puppies are loud! I have never liked the sound of a stebal, kinda like a kids train at the park. This set sounds like a 70's model V8 car.
I chose the PN 85110 400/500HZ (lower or deeper sound). Amazon has them at $45.35 shipped at the moment. That price fluctuates as high as $55. I caught it when they went back down to $45.
Per the wiring schematic in the OEM service manual, the horn is on a fuse all by itself (10AMP). The stock horn is listed at 2.5 amps per the book. The PIAA is around 5 AMPs for the pair per this post on the FJR forum. If the OEM switch in the handlebars can handle the doubled current as other here have had great success, everything should be OK.
I bought the following connectors and did not cut into the stock wiring at all.
Mounted the splitter connectors to the 1st horn in the OEM location.
Plugged in the OEM connectors to the 1st horn in OEM location. Made 2 jumpers to come off the 1st horn and go to the second. I mounted horn #2 just behind #1 as shown. I had to remove the splash cover from horn #2 to make it fit. This should not get much spray where it is located anyway.
Also, I don't care for the flashy decals they plastered all over the horns so I used a heat gun to soften the adhesive and removed them.
A few shots after putting the fairings back on.
Here are the connectors I picked up. Advance Auto was the only parts store (out of 4) in my town that stocked the 90 degree connectors. O'reily's stocked the splitter connectors.
Very pleased with the install and can go back to factory in minutes should I want to sell the bike.
Lastly, I brought my wife into the garage to show her the horns and give her a nice loud blast. She said "Damn those are loud"! :eek:
No more road runner "beep" "beep" :thumb:
Yeah sorry guys I was a bit frustrated last night and didn't do my own research. Nothing seemed to be going right. As usual though Cap'n Kirk comes to my rescue with an easy to follow guide with pictures.
Thanks all.
I will give it another go tonight with hopefully more patience.
"Get a relay and thick wires to hold the load."
As stlee29 says...good advice. You don't want the load from those beefy horns to melt your OEM horn wiring, which wasn't designed for the current load.
Thanks to Cap'n Kirk and his thread I was able to get these installed in about 15mins.
They sound great and no need for a relay.
Electrically speaking, that is excellent advice. But, I rolled the dice and have had no issues.
Can't say much about the switch because I have no documentation on its current capacity. At 5 amps, the current wiring should be fine as short bursts of current through the stock wires will not give them time to melt. Most wiring is rated more than twice the normal usage. Granted if you are a road rage kind of driver and you hold the horn for 15 seconds while flying the bird, you might pull enough to cause concern.
Another reason I decided to skip the relay is I have not read here or on any other forums about the Piaa's melting stock wiring. I am sure if someone has a casualty, they will post up!
Besides the possibility of frying your OEM wiring, also consider that the horns will only honk at their stated dB rating if they are fed sufficient juice. I have heard the difference side by side with Stebel Nautilus horns on ST1300s (OEM wiring and wired separately with the OEM horn firing a relay). Louder is better, whatever works for you.
1 - 12 of 12 Posts
