Phone/gps mount/ X300 / DIY over the Dash
7792 Views 10 Replies 7 Participants Last post by  MotoCoco
This was another little project that was completed over a couple different days as time allowed. An over the dash phone/ gps mount. I got the inspiration from a product made by Adventure Tech, and was originally going to buy theirs, but decided I had most of the materials to try it out myself. I had to make a little change for attaching the ram ball because I didn't give enough space for it to clear the fairing. I also ran into an issue because I ordered the wrong ram ball. I meant to get the 1/2" long post, but selected the 1/4" long one. I've made it work for now, but will be replacing it. Tested it tonight briefly, and it works well, I'll have to play with the positioning a little more though.
Sent from my SM-G950U using Tapatalk
See less See more
Reactions: 4
1 - 11 of 11 Posts
Very ingenious! And thanks for all the story-pics. It really is quite perfect placement, above dashboard.
Would like to see one more picture looking at the bike from the front with phone in place (not that that really matters).
Well done.
Reactions: 1
Well done.
I should be able to take a picture or two of that when i get home from work.
Well done.
ignore the very dirty windshield.... and unfortunately I needed the phone to take the pictures, so nothing with the phone in at this time.
See less See more
Reactions: 1
I really like my phone mounted there as well. Mounting it to my windshield is awesome. Doesn't block anything and gives you a clear view of the map etc without taking eyes off the road. So much better than a handlebar mount.
Reactions: 2
:thumb:Hats off to your DIY design. Very practical and functional.
I really like the way of fixing the phone mount. It really seems to be the best position, since its out of the wind and rain. and it does not move around with handlebar movements, so it shouldn't catch the charger cable eventually.
Also really like how you did the mount and the tutorial pics!!
1 question for me stays. Are the screws that hold the windscreen long enough to cope well with the wider space squeezed in? Or would you recommend longer replacement screws?
The bolts holding the windscreen to the bike seem to be plenty long enough in this application. I put a little blue loctite on them when I buttoned everything up a couple months ago, and I've had no issues with them. The only problem I've had is with the ram ball itself, and that's because I should have ordered the 1/2" long shaft instead of the 1/4"
Reactions: 1
Thanks so much for the reply!!
Nice job. I also designed a general purpose mount which is fixed behind the windshield. I used stailess steel sheet and an aluminium bar. I designed the outline in AutoCad and made the plate out of 1.5mm thick stailess steel plate using laser cutting. the 2.5mm aluminium bar lets you install a variety of devices. I use it for my Phone holder and Gopro.
See less See more
5
Reactions: 5
I know it's been years, but that mount is gorgeous, can we order?
Reactions: 3
1 - 11 of 11 Posts
