1 - 20 of 20 Posts
I'd like to take some 1-2 week trips this summer/fall on my Versys 650 and need to get some panniers. I've spent a lot of time reading about the different options available and have pretty much narrowed it down to these (although I'm open to other suggestions!):
1) Givi V35 Monokey side cases
From what I've read, these are the same as the OEM cases.
Pros:
  • They look nice
  • They are easy to remove from the bike
  • They look like they would be very aerodynamic
Cons:
  • Not waterproof
  • Questionable durability/strength (afraid they would break in a crash)
  • The curves would make it harder to fit rectangular objects (like a laptop) in the cases
2) Pelican 1440 cases
Not designed to be panniers, but who cares!
Pros:
  • Nearly indestructible
  • $200 cheaper
  • Waterproof
  • Much narrower
Cons:
  • Don't have that aerodynamic shape, so probably produce a lot more drag (but how much more? would it be noticeable?)
  • Would have to do some DIY work drilling holes in the cases and mounting them to a rack
Thoughts?
How do the pelican hook up ?
I manage to render my V35 relatively waterproof
I've run a peice of foam tape under the existing rubber seal
So when the cover are closed, more pressure is applied and thus getting a much better seal
Not perfect, but pretty close
LOP
I've had V-35s for a few years now and find them entirely acceptable. Don't have any problems fitting my laptop although I have to say it isn't an 18 inch model. I usually use hard case liners but haven't had trouble with water proofness (is that a word?). I'll also agree they weren't designed to absorb the weight of a heavy bike in a fall, but I'd rather sacrifice a hard case than expensive parts of the machine itself.
As far as the Pelican bags are concerned I agree they aren't aerodynamic although they're no doubt sturdier. To me they look like industrial strength medical waste containers. Not my cup of tea and not necessary for my riding style. Oh, and "much narrower" also translates to less interior space into which things can be stuffed.
In the end, it depends on your type of riding. If you're going to ride off road a lot and thrash about in the dirt and mud and sand, the Pelicans are probably the better bet. They may even hold a tipped-over bike off the ground without being damaged. And, from the saddle you can't see them. :D
And, if you decide on the Pelicans you could always put hazardous waste decals on each case and people might give you a wide berth on the road. Not a bad thing.
DOT would make you stop at every weigh station, charge you a fee, and then fine you too :eek:
I have 1520s on my KLR and they are the largest frame sliders you ever saw! :D BUT they hold a bunch of stuff and are easy to load and unload after I put some stops in them, these are a suitcase style unlike the 1440. I like them the 1520 are a bit on the small size for some folk but I suffer for Over Packer disorder and I'd pack my bowling ball collection if I could at times! I've had them for 6 years and not problem s or leaks.. To mount them I drilled holes and used SS screws to bolt them to the SW Motech brackets BUT Twisted Throttle has a mounting kit as well.
Looks good!
Do you feel like they create a lot of drag? Does the bike handle noticeably different with them on?
Also, what do you mean by "easy to load and unload after I put some stops in them"?
I don't thing there's much change in handling until I really load it up. Drag isn't really noticeable on a motorcycle like the KLR, it's a drag beast anyway.
The stops, I should have said straps just keep the lids from flopping all the way open and dumping everything on the ground.
Before
After
Before
After
That's impressive. Add a Kermit chair or two and they would a very nice roadside picnic table. :D
You know, I watched someone on a Multistrada that had Givi cases low speed/low side at Moto America in Utah a few weeks ago. Those cases were pretty good sliders in that case. I'm not sure if they build them so that the all plastic parts hit the ground and not the paint, but you could hardly tell she did anything.
I know the Pelicans would be the BEST sliders, because if you ever damage a case Pelican will replace the case for free less shipping. I just replace a few cases for work (BIG EXPENSIVE MODIFIED CASES) and it was no haggle and easy to do.
The Kappas are great. Just got back from a week in the high Sierras. Work like a charm. Also they were cheaper then the for like Givis.
+1. I bought the Kappa K40 side cases as they were cheaper than the Givi version. I used them this Summer in some terrible pounding extended rain - no leaks.
I also have Givi E21s. The top loading, I think, May be even better to ensure waterproof closure. And, I have dropped the bike with the Givi boxes taking the damage. Stopped in a gravel lot, got scuffs to the corner of the box but it was plenty strong enough for that.
Cons:
Thoughts?
I think your body will act as a "spoiler" for the Pelicans, so they will NOT get as much drag as they look like they would sitting there.
Will be mounting these on the BMW GS over the next couple of weeks
They ran $44.87 with shipping for the pair. A little weather stripping and some bolts and thumb nuts from the hardware store + some caulk and a couple reenforcing strips of sheet metal and they should be good to go. I already have a rack (came with bike) so should run me under $55 total.
I have the Givi 35V on the Versys. I have grown to love them. The ease of the push button open/removal is hard to beat. I laid the bike down once in at slow speed on a gravel turn and one came out with some scratches but that is it. It stayed on the bike and really only caused cosmetic damage.
My v35 bags have 40,000 miles of use between two bikes now. I like everything about them. Even added admorelighting LEDs to them and I can't say enough good things about them. I would be concerned with the pelicans for high speed stability, and winds. Had 1550 caribou system on the KLR and didn't like going over 65.
1 - 20 of 20 Posts
