When I got my bike used, the previous owner dropped the bike in his driveway slightly cracking and scratching up one of my v35 side cases. With a upcoming trip I wanted to fix the crack, and maybe try and make the scratches look better.
To fix the crack I drilled small holes on each side of it every inch or so, and used small zipties to secure it.(It is mostly covered by the removable covers) I then dremeled a deep v in the crack and filled it with a product called Duramix.
Looking at the covers I decided to paint them red to match the bike. Bought a can of "Red Pepper" in Krylon Fusion
It claims no sanding or priming required, but I found you need to sand the surface first, in order to remove the plastics shine and help with adhesion.
As the pieces sit now they are painted with many light coats and wet sanded. Tomorrow I am going to give them a final coat, but should I clear coat them as well?
I will post up pics as soon as it is all back together.
Hawkshot99,
:interesting:Just curious, How's the project going? Is the Krylon "Red Pepper" a good match? Got any Pics?
Hawkshot99,
The match is not perfect, but it's pretty close. The bags are all painted and look ok. I screwed up on the clear coat, and will get around to repainting them this winter.
Will post some pics soon. Have not taken any of the bike with the bags on in a while.
How did you use the clear coat on the paint and how long was the paint left to dry before clear coat.
Post some picture and thanks for sharing.
:cheers:
:cheers:
I think I dried the paint for 2 days. I screwed up the clear by applying it to heavy. I should have given it much more of a mist application. When it dried there were a bunch of cracks in it that I could not wet sand out without starting over with paint.
Clear coat is a bit tricky as some paint cannot take clear coat and clear coat should be applied in layers- mist and light spray per layer and finish with polishing.
:goodluck: On the next round of painting.
:cheers:
