1 - 20 of 23 Posts
Hi. I am about to take a oil change but noticed that most of the plug gaskets are copper. Wont this wear on the alu engine?
Copper washers should be annealed each time they are dismantled and re-used. Heat it with a propane torch (those new butane lighters would probably do) until it glows cherry red. It can then be quenched in cold water. That will ensure a good seal and eliminate any brittleness. They can be re-used many times.
I did not have one either when I went to change my oil last year, and could not find a copper one at the normal suspect stores. What size do we use, and are they compatible with putting on a magnetic drain plug. If I recall you have to buy 6 to 12 if you purchase them online. If somebody is buying a few, I'll split the cost and pay for the postage to send to me.
Kawasaki part # 92065-097 ($0.34 MSRP). 12 mm hole, 22 mm outer diameter, 2 mm thick.
Kawasaki recommends changing it at every oil change. I buy six at a time. You can also anneal as described above. I've been buying my crush washers (among other things) HERE for a couple of years (for different bikes). The last batch they just posted in an envelope so shipping was like a $1.00 or something.
Yes they are compatible with a magnetic plug unless the new plug has an integral rubber washer built in (many cars have this but the magnetic plug I bought for my motorcycle did not).
It MUST be quenched to anneal (soften), and you can generally get them fairly cheaply at O'Reilly or NAPA auto parts - look for 1/2" copper ones. (I have one previously annealed and quenched, to exchange as I change oil, then I do the 'take-off' one.)
The function of a "crush washer" is to keep from grinding the steel drain plug into the aluminum case, especially for those that over-torque the drain plugs.
Nothing high tech here. Change it when it looks damaged.
Copper or aluminum. Both work just fine.
No need to anneal them.
Gasket # 92065-097
Hello Folks,
I have a 2018 Versys 1000 and looking to do first oil change my self, still breaking-in the engine.........
Searched everywhere but do not see gasket # 92065-097 easily available or price is $$$ and shipment may take a very long time.
Any one bought them recently and can point me in that direction?
Found 1 Gallon Kawasaki Performance Oils 10W-40 Motorcycle Oil
Found BikeMaster Steel Magnetic Oil Drain Plug 12mm x 1.5 # FHM050-S12
But can't seem to get the gaskets.
Thank you,
Vadim
Hello Folks,
Thank you,
Vadim
M12 x 20mm crush washer. You'll find them everywhere (Amazon, AutoZone, HomeDepot, eBay...) just make sure they're soft aluminum or copper and you're good.
BTW, I only replace the washer every 3 or 4 oil changes. You can use the same if not damaged. Inspect it before replacing.
Or just go to an auto-parts store (like O'Reilly Auto Parts) and buy a small package of 1/2" copper washers (fairly inexpensive).
I anneal mine when I change oil (which 'softens' it) and re-use.
Aluminum washers aren't able to be annealed w/out very sophisticated equipment (IF at all!).
Hello Folks,
Thank you,
Vadim
On my V-1000 i went with this magnetic plug....https://goldplug.com/shop/mp01/
The washers for it.......https://goldplug.com/shop/sw03/ .....When you check out on their site you have an option to pay with your Amazon account i believe its free shipping. I know it cheaper to buy it that way.
Also you can get good deals on Motul 7100 10w40 on Amazon also....https://www.amazon.com/dp/B00IKCY9RK/ref=nav_timeline_asin?_encoding=UTF8&psc=1
P1010566 by weljo2001, on Flickr
P1010567 by weljo2001, on Flickr
P1010568 by weljo2001, on Flickr
P1010571 by weljo2001, on Flickr
Thank you! Found some soft aluminum M12 x 20 drain plug washers on Amazon.....
Good suggestion, will keep that in mind - Thank you!
Thank you Everyone!
Really appreciate all the help\suggestions!
Did my first EVER oil\filter\bolt change today. While the bike was cold I wanted to make sure I can unscrew filter and drain bolt. At first had a hard time unscrewing the filter using a adjustable grip pliers, filter was on tight. Tried the auto store for a more dedicated tool but all were a bit to large. Went back to the adjustable grip pliers and squeezed tighter and finally the filter turned. Other than that scary moment, the job was easy peasy lemon squeezy. Thanks guys!!!
1 - 20 of 23 Posts
