1 - 5 of 5 Posts
Has anyone experienced any oil leaks. I have what seems like a leak which looks like it is coming from where the chain cover is bolted to the engine. I am still breaking in the bike. Only 650Kms on it so far.
Auto part Engine Automotive engine part Metal Clutch
Auto part Fuel line Vehicle Fuel tank Automotive fuel system
Auto part Engine Automotive engine part Vehicle Metal
Take the countershaft sprocket cover off (2 bolts) and inspect. It could be a leak at the countershaft seal. Check if the oil comes from behind the sprocket... At any rate, it should be warranty covered.
did you get it fixed? i have the same problem but warranty is over. help me pls.
I believe I had a similar issue. I took it to get checked out and it seems that when I removed the air box to install my juice box I did not re attached a...and I forget the exact name..but.. the crank case breather hose?
1 - 5 of 5 Posts
