1 - 19 of 19 Posts
I bought an oil filter wrench for the Versys today at Walmart. It only cost $3.26 and fits over the outside of the filter's end like a socket. You the put your 3/8 drive ratchet into opening of the device and spin the filter off. It's made in the USA by IMPERIAL, part no. IF-6567C.
what mm is this wrench?
I got lucky today. My sister had a mid-90's Toyota Cellica while in college and I still had the wrench for it. Sure enough, it fits the Versys oil filter as well!
speaking of oil filters, does anyone have any cross references for other brands i might get at my local auto parts store instead of dealing with just the dealership part?
K&N makes one that I just installed. It has a nut attached to the front of the filter and installing it was a snap. The part number is KN-303.
OEM oil filter: 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket, 2.5" height, 2.7" OD. If you have the room, I recommend the longer filters.
http://www.calsci.com/motorcycleinfo/FilterXRef.html
-See Section [5]
Motorcycle Filters - None are recommended:
* AC Delco PF2135
* Carquest 85358
* FRAM PH6017A
* Honda 15410-MCJ-000
* K&N KN-204, about $13. Metric nut on end for easy removal. (KN-303 is the longer version)
* NAPA Gold 1358
* Purolator ML16817. Imported, not made by Purolator.
* STP SMO 17
* WIX 51358
Recommended filters - All have superior filtering:
-About 2.5 inches long:
* AC Delco PF1237
* Amsoil EaOM103, $14.80
* Purolator Pure One PL14612, about $6.
* Mobil M1-108, about $12. Made by Champion.
* Bosch 3300, about $6. Made by Champion.
* Baldwin B1400
* Emgo 10-82230
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* Vesrah SF-4007
* WalMart SuperTech ST6607
* WIX 51365
-About 3.25 inches long:
* Amsoil EaOM103C, $17.00
* Purolator Pure One PL14610, about $6.
* Mobil 1 M1-110, about $10. Made by Champion.
* Bosch 3323, about $6. Made By Champion.
* WalMart SuperTech ST7317, about $2. Made by Champion.
-Automobile Filters, about 3.25 inches long:
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Carquest Red B4620
* Casite CF240
* Castrol 7317
* Champion Labs Ph2867
* Defense Filters Dl7317
* Deutsch D-370
* Federated Filters LF240F
* Fram Extended Guard XG7317
* Fram Extra Guard PH7317
* Fram Tough Guard TG7317
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Motorcraft Long Life FL-821
* Napa FIL1356
* Napa Gold 1356
* Nippon G6Y0-14-302 A
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Gauge PGO-4620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Service Champ OF-4622
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
I got 6 high quality Nippon G6Y0-14-302 A PH oil filters from Ebay for only $12.99 ($12.99 for 6, not $12.99 each) plus shipping;
http://cgi.ebay.com/ebaymotors/6-Ni...38494462QQcmdZViewItem?hash=item270238494462&
-See Section [5]
* AC Delco PF2135
* Carquest 85358
* FRAM PH6017A
* NAPA Gold 1358
* STP SMO 17
* WIX 51358
* AC Delco PF1237
* Baldwin B1400
* Emgo 10-82230
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* Vesrah SF-4007
* WIX 51365
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Casite CF240
* Castrol 7317
* Deutsch D-370
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Napa FIL1356
* Napa Gold 1356
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
well if your putting it on your Versys, I must have the room for the longer one too?
I bought the wrench from Wall Mart and it works on the Fram filter but not the oem filter? Maybe its not the same.:confused:
I can confirm that the current Wal Mart cheap wrench doesn't work on the oem. I think it is a Fram branded wrench.
Mine is a Fram oil filter wrench, F1105. It fits the Fram filter not the Kawi OEM
My bad, not the same wrench or socket for the filter.
Donn:D
The Walmart wrench worked on my OEM filter after I wrapped some masking tape around the filter. The OEM was installed exceedingly tight, IMHO. I applied torque to the old filter very slowly, and it finally started to move.
I started torquing the new filter to spec with a calibrated wrench. and I stopped short of the recommended spec, it seemed way too tight to me.
So my Supertech filter is installed by feel, and no leaks in 700 miles.
Administrator
Install filters by feel rather than toque as dismantling becomes a problem. Have done several chnages on oil filters on bike and car , all on feel. So far no visible leakage and good.
:cheers:
MOST of the filters I do (car...) say to tighten till contact, then another 3/4 turn. I would NOT use a torque wrench on one. :thumbdown:
I understand using a filter wrench for unscrewing, but I've ALWAYS tightened my oil filters by hand (with maybe a tiny bit extra force with the wrench)--and I've had no problems so far.
1 - 19 of 19 Posts
