1 - 20 of 31 Posts
new to me at least, picking up a 16 LT model with 3k on it this sunday, a few nice addons, like a givi rear carrier plate, adv monster lights. 30 mm risers, motorwerks footpeg lowering blocks, new TKC70's and a bigger puig windscreen.
gotta move to a lighter bike, the concours 14 im on weighs 700+ lbs and im actually nervous riding it. i shattered my left leg and down to 60% use, just enough so that if i drop the big beast i cant pick it up anymore. parking lot/ garage shenanigans are exercises in hoping i dont tip over.
this looks like the lighter bike route to go.
on a related note, who makes a good centerstand. have the homemade crutch jack for my KLR. but really prefer a centerstand for a touring oriented bike.
I have a prop stand, which allows me to lift both the front or rear wheel for chain lube or tire plugging, it fits easily in the top of my Trekker case, I don't know of any other simple device that lifts the front wheel, strictly for tire plugging. Cost me nothing, to make less than $25. I have photos in the How To Forum. When home I use a pit stand or the Venom triple tree stand. That is a lowered 2015 650 Versys, I used the same when I had the 07.
need to get a front stand, ive always had centerstands and just tied the rear down to work on the front, venom brand you say.
have a rear stand, can a versys accept spools?
I have a '15 with now 67k miles on it. I came off of a c-10 Connie that hauled me all over N. America. The itty bitty six fiddy does a marvelous job in it's place and is really a blast once you get to there once you farkle it to want you want/need.
BTW, a Rostra cruise control is installable, quexpress did a marvy write up on it, though you will have to mount it in a different location than he shows on an LT. I replaced the evap canister on my bike.
Yeah, I’m kinda obsessive about it. Also helps that I don’t ride in the rain or do any dirt or gravel roads. At my age, and health, I’m a fair weather rider. I’ve got a KLX 250s to get dirty, and occasionally go trail riding with my Grandson.
Actually, I’m no where close to the cleanliness that Weljo2001 does! I was in awe of the post where he cleaned out his sprocket cover!
picked up the newish LT model today, after riding it round a few hours here are my impressions of it.
its not tall. not to me at least. 5'9" w a 32 inseam and its perfectly doable, not flat footed doable but balls of both feet down with good control no problem.
gotta do something with the seat, that driving me into the tank shiznit has GOT TO GO. ill be taking a closer look at the spacer mod to get this under control.
then when i can actually sit on the whole seat ill see if its gonna be long distance worthy. theres a medium alaska sheepskin pad on standby..
it turns QUICK. its compact front to back and the steering is light the TKC 70's that are on it now will probably live out their natural life. but a set of good sport touring rubber is going on at the first swap
theres a puig touring screen on it now, the stock was included in the deal as well, itll probably stay in the plastic the puig does pretty well. and ive got good klim/stitch gear to handle any rain that gets by it. thats gotta be a windmill from hell with the little stock screen, not for me.
suspension feels a little soft need to break out the sag tape and get it set up to my 220lb self.
brakes, heard a lot about how the slide pin brakes are inadequate, not so much im thinking get into the abs and the rear wheel is floating thats good enough and more than most can handle, probably hit up speigler for a set of braided stainless lines. i prefer braided lines on all my bikes anyway.
motor, a bit fluffy under 4k but wants to rev like nobody's business. and decently smooth as well, yay rubber engine mounts. may get a flash from steve to clean up the low end, top end is fine.
gearing..WHOA stop 6000 rpm at 80mph indicated? is this normal. there may be a 43 tooth rear in the near future. im not used to running that many revs, motor seems perfectly fine with it
im a bit bugged out about it tho.. thats not natural. remember im coming from a concours 14 turn 6k on that in top gear and you are well north of go to jail speeds.
the luggage is good, kawa did a nice job on it. obviously made by givi but still they put the effort in to provide decent luggage. it will even fit my schuberth C3 pro lid in a side bag with room for other stuff, not a lot of side cases can manage that. well done to kawasaki.
lighting, headlights are meh, not the worst, but could be better. i have a set of cyclops H7 led bulbs that were supposed to go in my klr, ill try em in the versys and see what happens. if theres a bracket that will let me mount some good cyclops optimia driving lights without having to mount a crash cage please speak up.
dash layout, not bad, like the dual tripmeters and it has a fuel gauge yes!! the tach is good and legible, the digital speedo is weird to my old fashioned self but its easily readable ill adapt.
need to hit up motorworks for the above the dash bracket to mount my GPS and a voltmeter/usb charging port.
OH and which little 5 foot nothing 120lb size 4 shoe wearing engineer designed the footpegs. the bike came with motorworks lowering blocks on it but there not much there to lower. does anyone know of a bigger footpeg suited to someone with a size 11EE foot? that will fit this bike? they feel like tricycle pedals after the plastic is broken off of em..
those are my first initial impressions after 3 hours of ownership. feel free to comment in fact please comment of you have any ideas, especially in the gearing and footpeg dept..
Yep, 6000 RPMs at 80. That's normal. The cool thing is it is also normal to get 50 MPG running 80. At least I do on my bike running Freeways and I weigh 250 right now.
Welcome to Versys ownership. It took me a little while to get used to some things with it but you will love this bike very soon. Believe me.
...OH and which little 5 foot nothing 120lb size 4 shoe wearing engineer designed the footpegs. the bike came with motorworks lowering blocks on it but there not much there to lower. does anyone know of a bigger footpeg suited to someone with a size 11EE foot? that will fit this bike? they feel like tricycle pedals after the plastic is broken off of em..
I run DR650 footpegs on both my V650s. JUST require a 3/8" bolt rather than another metric one.
Once you raise the front of your seat you'll feel as if you spent MUCHO dinero, BUT didn't...! About $3 for a piece of scrap, two 6x45mm bolts, 12 = 1/4" washers.
DSC00059A by Ed Copeman, on Flickr
DSC00060 by Ed Copeman, on Flickr
seat rise1 by Ed Copeman, on Flickr
so i got the seat mod done, a few spacers and washers along with a piece of heavy gauge metal from work. works a treat, no more sliding forward.
found an extra harness for my wolfman blackhawk tankbag to itll swap between the concours and the versys. the blackhawk is the perfect size for this style/size bike. i have an explorer model that is huge and fits better on a bigger bike. or makes a good tailpack.
added the kawasaki relay under the dash and installed a voltmeter /usb charger along with a spare ramball i had and my old xgrip for the phone/ radar.
bought a set of the sw-motec driving light mounts from twisted throttle. relatively cheap for swmotec and TT like 60 bucks shipped. got them installed after more time than i want to admit on the install. motec install instructions are sparse to say the least,that and my natural i dont need instructions nature is a bad combo. but its done anyway, ill post pics to help whatever other poor soul wants to try it. (think monkey/basketball and an 8mm hex socket)
Ill move the PO installed advmonster model 19 lights from the low foglight/bodywork breaking position to the new mounts and wire them thru a skene dimmer and see how they work. if they are good then good enough if not a set of model 55's looks to be the deal
tried, note i said tried to install some good cyclops H7 led bulbs, swapping a conventional bulb on this bike appears to be duck soup, its right there easily gotten to. getting the retaining wire around the large heatsink on the cyclops leds however is another story, i know these will work, they work on my h7 klr lights but i had to pull the front cowl to get them in, probably gonna have to do the same with this bike as well.
ill start stripping stuff off the klr like my fz1 fuseblock, gps mount/wiring, radar detector mount/wiring and heated gear wiring this week and get it ready to sell. after 12 years and 50k hard adventure touring miles i dont expect to get much for it even with the nice toys on it so off they come.
after that stuff gets transferred ill start with the heated grips, looking at getting a set of oxfords unless someone has a better suggestion?
the GPS and detector will power thru the relay up front and the heated gear/lights/grips will go thru the fuseblock under the seat, the area at the back near the taillight looks like a good spot for the powerblock and theres an accessory circuit for the relay right there.
did stop by cyclegear and get some 8mm spools, now to find the spool adapters for my stand. been using the flat style adapters with my klr for years.
eventually ill get a centerstand. im on the road 250+ days per year and a centerstand is nice for maintenance or plugging/patching a tire in the middle of nowhere alabama. and WOW they are proud of them.. but i cant exactly just throw this one over in the dirt to fix a tire/chain like i did the klr so its a must do eventually.
oH and i really want the over the dash mounting plate for the gps that motowerks sells. that looks really well done and i think it would be better than the handlebar mount option.
...after that stuff gets transferred ill start with the heated grips, looking at getting a set of oxfords unless someone has a better suggestion?....
KOSO Apollo heated grips. Work GREAT w/ a built-in switch on the left grip.
IMG_2849 by Ed Copeman, on Flickr
IMG_2850 by Ed Copeman, on Flickr
...oh and i really want the over the dash mounting plate for the gps. that looks really well done and i think it would be better than the handlebar mount option....
I made my own for my Gen 3.
P6211173 by Ed Copeman, on Flickr
P7272584 by Ed Copeman, on Flickr
P7272582 by Ed Copeman, on Flickr
oH and i really want the over the dash mounting plate for the gps. that looks really well done and i think it would be better than the handlebar mount option.
If that's the SWMotech mount, it's not as good as it looks. After about 20k miles the two plastic pieces that slide together developed play and causeg whatever is mounted to shake up and down quite violently, not a good execution of a pretty good idea. I wound up removing the plastic crap and mounted my RAM mount directly to the base shelf. Not real happy about paying $80 for something that was shot in a year
If I were to do it over again I would get a piece of 3/4" PVC pipe, run a piece of all-thread through it and the windshield brackets and use handlebar style mounts on the pipe. The SWMoetech unit will also interfere with the Madstad windshield system adjusting mechanism if you chose to go that way for a shield(highly recommended).
Discussion Starter #16 (Edited)
updating the progress so far
16t jt front sprocket, it feels a tiny bit harder to get moving from a start but pays dividends on the road with less rpms for a given speed and the speedo is correct to within 1mph now. the gears are so closely spaced that final drive selection is mostly a matter of how hard you want to drive the bike.
swmotec front driving light mount brackets installed, not for the faint of heart or clumsy of finger, they have to install from the bottom. the bracket goes on top of the front fairing stay and the cushion blocks, spacers and bolts have to be installed looking up. the motec instructions arent really clear on this. took a bit to figure it out.
installed the factory kawasaki relay and am running the voltmeter/usb charging ports from it along with my gps. i like how kawasaki did the access for this 2 screws and 2 pushpins and youre in.
mounted a ramball on the left mirror mount, the gps is riding there now. may stay, may move to a motowerks bracket,
pulled the wiring harness and gps cradle for the garmin 660lm off my klr and got it installed. if you travel a lot you dont really notice how much you use one till its not mounted on your new bike.
relocated the previous owner installed advmonster model 19 driving lights from the side of the fairing to the motec brackets, and re-wired the power connection. the PO had them straight from the battery just waiting for me to forget to turn them off and draining the battery, they are powered from the aux light lead under the left fairing now.on/off with the key switch or the microswitch on the bars once the key is on. theyre only 22w for the both, theyll be fine. wouldnt run a pair of 55w lights from it but theres plenty for a pair of 11w lights. led lighting rocks.
what else, did the seat raise mod so i dont slide forward, thats the best 10 bucks youll spend on the bike i think. the foam is kinda thin to me, so the sheepskin helps with the seat.
added a bit too much 3m reflectix tape to the rear. however noone can say they didnt see me at night
added a tender lead with the coax adapter so i can run my heated gear.
things to do
removed the fz1 fuseblock from the klr and will get it installed this week, thatll power the heated grips when they get here. and will move the tender and heated gear leads to it.
was going to order a valentine radar detector, my old escort x50 black is past its prime, it alerts on every lane sensing radar within 50 feet. however theres not a V1 to be had. theyre coming out with a new model and the old one is discontinued. there are way too many localities in the south that depend on traffic ticket revenue so this is a must have for me, F'em they can raise taxes im not paying the mayors salary.
I have to break down and pull the front mask and get the cyclops H7 led bulbs installed. the factory lights are weak and look like an afterthought compared to the driving lights. im on the road working out of my toyhauler so next time in in ill remember to grab the skene dimmer off the shelf and get the driving light working properly, but it'll be mid november before i make the trip in so ill probably just order another one before then.
also the topbox that i thought was a givi from the craigslist ad isnt a givi, its a bestem/emgo. sort of a mini givi, the mounts look the same but the spacing is way different so none of my givi boxes will mount on the plate. so, theres a custom made aluminum givi mounting plate on the klr that ill transfer over. i made it out of a 1/4" thick pump mounting base. and sell the klr with just the stock rack on it. a bit of drilling and maybe a few spacers and it should work out. the arms for the emgo box look plenty sturdy. i dont run with a lot in a topbox its mostly for groceries and to stash my jacket/helmet at stops. but the big mounting plate i made will carry my 40l drybag with my camping kit perfectly.
lets see, what else need? done? handguards, need bigger handguards the stock LT handguards look nice but i would like a bit more coverage for winter riding. does anyone know of a bigger handguard cover that will fit without extensive modification? im running maier atv woods pros on the klr, big and ugly but very effective. I would like something similar for the versys.
...lets see, what else need? done? handguards, need bigger handguards the stock LT handguards look nice but i would like a bit more coverage for winter riding. does anyone know of a bigger handguard cover that will fit without extensive modification?....
Try "Hippo hands" like weljo does on his V1000...l
Discussion Starter #19 (Edited)
little progress to report, been mostly riding it. theres a skene dimmer arriving tomorrow and a set of oxford sport version heated grips waiting to be installed. along with the fz1 fuseblock i pulled off the klr.
i went with the sport over the adventure style grips due to the fit, you dont have to trim them and they are a little fatter which i prefer.
I did get my givi mounting plate installed, my v46 now rides with me ill get a pic of the install up asap. i built this in 2002 out of a pump base that installed for a customer. its seen over 200k on 3 different bikes, this will be the 4th bike to wear it.
did get some interesting numbers about the charging system tho.
trying my 90w warm-safe jacket liner the other evening. I can run the liner at full load toughly 108w at 14.1v with the 10w driving lights on for another 20w load and hold 14.1v on the voltmeter. adding the highbeam for another 55w drops the voltage down to 13.8v
the stator/RR will put out full voltage of 14.1 v at 2200 rpm so basically if youre moving youre getting all the power it has.
this is a a nice change from some that dont make full output till 4000 rpm or so
my voltmeter is only .1v precision and ift fluctuates between 14.1 and 14.2 v at full load. the true rms reading is somewhere in the middle i think,
but for practical purposes 14.1 is what i define as max v/output.
I didnt add the heated gloves into the circuit, that would be another 36w load but ill have the heated grips installed next week and get a reading with them on then. i like to maintain 13.2v to avoid battery discharge. if i cant get that with the grips on high and hi-beam on ill install the LED headlight bulbs which should save 40w or so. and may let me run grips and gloves both, run them both at a low setting and you never feel the cold at all at least on other setups ive ran. if its cold enough to run them both past 50% its too cold for me to be riding. even wearing the roadcrafter with baselayers theres a limit I can take, did it at 12 degrees F a few times but im older now and that isnt fun anymore.
with the way the oxford controller works< i may not need to add the fuzeblock, ill have to puzzle that one out. probably will tho. if theres a way to kill a battery in the middle of nowhere ill find it so i think the relay controlled central power is prolly the way to go. rather than trusting the grip controller to shut them off if i forget to.
I need to research whether the power for the skene dimmer can be taken from the driving light lead under the fairing or if it needs hooked to the battery/fuseblock. im referring to the power for the unit that it consumes, I have power for the lights which will come from the aux light lead but theres a seperate power just for the unit that may need to be on a battery to maintain settings.
the fz1 fuzeblock has two choices for each circuit,relay controlled or battery direct depending on which side you put the fuse in. but thats another wire going back to under the seat. that ill have to open up the harness to add in, all this stuff takes a bit to install.
need to get a thermobob installed, had one on the klr and it worked great, tho the install on the versys looks to be considerably more complex,
same connections but a lot more stuff to move to get to it. if nothing else ill have a really good understanding of how to dismantle a versys 650 before this is done.
1 - 20 of 31 Posts
