1 - 17 of 17 Posts
Hello everybody,
I'm new to this forum looking for information's about Versys . Now I own an old Suzuki VX800 and decided to buy a new present for my birthday this year - so I bought from another country, from a Kawasaki dealer, a 2010 Versys with ABS ( 6800 km on the clock ) some weeks ago and waiting to bring it home ( hope this week ).
Here are some pictures with it.
I'm so excited to ride it and looking forward to learn from everyone's experiences with this bike.
:welcome:aboard and enjoy your new ride- Be safe.
Feel free to ask anything you want to know about the bike and there are tonnes of information here to make your riding safe.
PLEASE POST YOUR SECOND POST HERE IN THIS THREAD YOU STARTED - THANKS.
Thank you all for "welcome" .
Yesterday the bike left to his new home. Only 1650km far away but today evening or latest tomorrow morning hope we will meet finally.
If you have any recommendations for this model regarding maintenance, what to check before going to trips or even for performance improvements please share with me. The dealer from which I buy it and also the transporter told me that the revision was made before to leave from them.
Hello,
The motorcycle arrived today morning.
Here are some pictures made by me after delivery.
Registration plate should come next week...
Here it come first impressions after first 100 km :
It drives well, higher position than previous bike, spongy rear break, 4 l/100 km (58 mpg calculated at gas station with 2 fill ups), harder seat - but of course you all know this.
I discover something strange: when I drive at low speed(30-50 km /h lower than 5000 RPM ) I find that the engine is working somehow interrupted, not smooth, continuous. If I accelerate or If I pull a little the clutch and keep same rpm it runs good. I don't think is a normal way of working for this bike. I change gears as in manual.
Could you be so kind and advise me what to check ?
Thank you .
Welcome! Not sure why it isn't running smoothly at that RPM, but it's not normal :frown2: I have a 2014 with over 32K miles and it doesn't have that problem. I'm sure others will have good suggestions on how to diagnose and fix. Good luck!
Not many VX800's left out there - I had a '90 several years ago. "Unique" motorcycle :wink2:
...I change gears as in manual....
Start changing gears at whatever speed within reason that just feels right.
I change up around 3,000 in normal around town riding.
Thank you again for feedback.
@Oldandslow : yes, VX is a "unique" special bike ( my first one ) and is still on my "garage" . I wish to keep it as long as I can. I'll put some picture with it.
@fasteddiecopeman : I tried to change gears as in manual but usually I do it as I feel is good. I'm not a high rpm fan neither a low and after I discover this I tried to change as in manual with no improvements.
I was digging into the forum and on the internet and found these :
Modifications - Performance - V-650 > Booster Plug, yes! (BP collective findings)
and
on youtube : Boosterplug. Fitted & 1st Impressions. Versys 650 by Andy Man Cam
I couldn't explained very well what I felt but these are the words:
" I can't do 25km/h at 2nd gear smoothly. it does do that ON OFF thing where it injects fuel,then not and then injects fuel" - first link
"The too lean air/fuel mixture on the standard bike will make idle and low speed running weak, and the throttle action will be horribly on/off like." - comment on youtube
Administrator
and
I just copied many posts related to your issue, one really key problem is the TPS setting, I had the same problem on my 07, however this was a non oxygen sensor made for Canada bike. Very early posts by Invader had a photo of the TPS tweaking it slightly like moving it 0.015 of a inch, just loosening or tightening the torx screw can affect it. I recommend using a 2 decimal place digital meter and the wire harness from Kawasaki
https://www.kawasakiversys.com/forums/74-how-forum/221685-booster-plug.html
https://www.kawasakiversys.com/forums/74-how-forum/122090-throttle-position-sensor-tps-modification-mk-1-mk-2-mk-3-a.html
Thank you @onewizard. I will try to modify the TPS but first I have to read service manual. I'm new to Versys world and I have to find location of these sensors.
I didn't even think that a bike with less than 10k km on the clock would run so bad at city's legal speed. I don't like to hear the engine scream (>4000 rot / min ) just not to have this on/off thing.
Hope this settings for TPS will solve the issue.
Discussion Starter #13
Today i've change idle from 1100 to 1300 rot/min and notice a great improvement at low speed: no on/off when acceleration was pulled a lot less than I used to. I will try few more days with this setting but I woud like to accelerate a little more than today and quicker. The bike accelerate very good from 2500 rot/min , the problem was when I tried to mantain 30 to 50 km/h in any gear without on/off feeling.
I've located TPS sensors: grey and black one. If today's setting will not work I'll go for TPS changes.
I've found this forum very usefull and clean ( without off topic discussions) . Congratulations to all of you.
Trimis de pe al meu SM-J530F folosind Tapatalk
Discussion Starter #14
Hello again,
After few days since I change the idle here is my conclusion: the bike runs better with new setting but when outside the temperature is higher than 20 Celsius it does that on/off at arround 2800 rot/min.
Today I rode in the morning at arround 15 Celsius and the engine works smooth without even one hesitation at any speed 0-100 km/h , any gear and any rot/min.
Since last change of idle the engine stoped once at first start in a cold morning and I started again without problems. Maximum idle at cold start is below 2000 rot/min and decrease to 1300 rot/min after max 2 minutes of idle.
It is possible that the bike to be setup for cold weather or it might be others problems like...( you name it)? Now that I located TPS sensors I need a multimeeter to do the changes.
Is there a page in this forum where we can find some documentation for these bikes? I have owner and service manual for 2010 in pdf format and can share them if needed.
This is my old special ( first one) bike .
Looking forward for your inputs.
Safely enjoy your rides.
Administrator
Hello again,
https://www.kawasakiversys.com/forums/74-how-forum/122090-throttle-position-sensor-tps-modification-mk-1-mk-2-mk-3-a.html?highlight=tps
Discussion Starter #16
Hello again,
After I read service manual regarding Main throttle sensor ( 3-40 -> 3-43) few time , view some youtube videos yesterday I started to measure the wires at main throttle ( grey ) in order to accommodate with the multimeter ( I'm beginner at this ) and I found that middle lead has 5 V. I can not continued from this point because I didn't had additional adapter. Nevertheless after I plug in the wires the bike ran different than before in a better way: I didn't felt that on/off and the engine seems to run more smooth. Could be a bad connection to these wires in the past to cause that bad feeling ? If yes how can I prevent to happen again ? What and (if possible ) how should I check ?
Please advise if these ( bold/underline) checks wrote by invader can be performed on my 2010 Versys, taking into consideration that middle wire has 5V
"...maximum throttle reading is back up to 4.21 V and idle at 1.1 V (meter '+' on bottom, meter '-' on top), with input voltage (meter '+' on middle, meter '-' on top) now at 4.99 V (standard: 4.75 - 5.25 V)" - post#3 : https://www.kawasakiversys.com/forums/74-how-forum/122090-throttle-position-sensor-tps-modification-mk-1-mk-2-mk-3-a.html
Regarding millage I get 51 US MPG ( 4.6 l/100km ) in heavy traffic.
Regards,
Robert
Administrator
Hello again,
Regards,
Robert
That same thread I provided a link for, go to my post 84. That is a 2015 but the values are valid. That section 3-40 to 3-43, is very important, you either need that adapter or make one, the output voltage is critical , FYI if you adjust this sensor, you need your meter attached during the tightening of the Tork screw, just the movement of the thickness of a human hair can cause a huge swing in output. Pay attention to the instructions, some readings are with ignition off & then on, some are after warm up. Also note mention of the ECU grounds, found near the frame ground on the 2010, footbrake side near the seat / tank support bracket, several members found poor or corroded connections here , also the ECU depends on the steel frame for those grounds, I would also suggest checking the engine ground.
1 - 17 of 17 Posts
