Hi all I just bought a V650, 2017 Get 3 model, 10k miles on the odo when I bought it, bone stock except it came with the Kawi OEM top case bracket, no top case though
Since I bought it from the dealership, have ridden it for about 600 miles. I changed the engine oil (although it wasn't that dirty) , changed out slightly worn very squeaky OEM brake pads for EBC HH sintered, installed a set of T-Rex front crash cage, installed LED light bulbs. Otherwise just been enjoying the bike.
Really like the bike so far, super comfortable coming from a Ninja 300, and love how nimble it is even vs. the Ninja.
However a couple of things I noticed, just wanted to get everyone's thoughts on:
1. I'm hearing a slight but noticeable ticking noise coming from the engine (most audible from the left side), mostly after the bike is warmed up to operating temperature. I changed the oil and added in the seafoam to a tank of gas to see if that'll quiet it down a bit, but so far still there. I checked the exhaust manifold bolts, they seem tight. Before looking into valve clearance (although at 10k miles is that normally an issue?), I think I want to check to see if the CCT is the culprit here. I've searched the forum came across various different answers, but wanted to see if anyone has any thoughts. If I were to try the one click method of tightening the cam chains, would that hurt the bike if it turned out not to be the issue? I guess it would just whine and I can just reset the CCT after that right?
2. The radiator fan turns on very frequently, every 4-5 mins if I'm idling and bike is sitting, for approximately 15-20 secs or so. Do I need a radiator flush or is that normal for the V650?
3. Idle sometimes is unstable, I would set it for ~1250rpm when warm but then sometimes when I come to a stop at a light or stop sign, bike would idle at 1500 or go down to 1100 in first. It's happening much less since I added the seafoam but maybe that's just wishful thinking. Not sure if anyone else have experienced this.
4. Engine seem to only like >3000 rpm in anything but first gear. It would lug if I'm below that range at any gear above 1st. Even when starting from stop on 1st gear, engine seem to struggle a bit if I'm not revving it up a slight bit more and feathering the clutch. Bike performs well >3000 though, no issues above that it seems.
Anyways apologies for the long post, but figure I get these all out of the way.
Safe riding everyone!
