1 - 20 of 21 Posts
New rider here with questions about buffeting. First, what is buffeting, and how do the different factory wind screen settings affect it. I am 6'2" and have a fairly long torso, so I sit relatively high. Currently, the screen is set to its highest position. I understand helmet type may affect it as well. Thanks for the advice. Great forum!
Mostly "buffeting" refers to movement of your helmet caused by turbulent air hitting it. Try lowering the windshield if you get it to have your helmet in 'clean' air. Try standing on your pegs to prove this.
When it feels like somebody is hitting you in the helmet with a hundred pillows, that's buffeting. I'm 6'3", currently running the stock screen at the highest setting, and I get no buffeting on the open road. When a car is in front of me, I get a little, and when a mini van or truck is leading, I change lanes because it gets to be too much. I've also run the Givi D410 screen, which reduces wind pressure on the torso but adds it's own buffeting straight to the face. You'll really have to play around with different screens and settings before you find something that works well. I don't think there's a screen available for us taller guys that will be buffet-free and isn't fashioned out of a barn door.
I am only 5'10" and I was feeling a lot of buffetting. My solution was a GIVI windshield from twistedthrottle.com $114.30 which was a vast improvement. I set it at the highest setting. That by itself was working for me. A couple of months later I bought the mra xscreen spoiler for $105 the clip on from the same online store. That again was a vast improvement from just the givi. NO BUFFETTING AT ALL for me.
Now since you're considerable taller, you might have to tweek with it to your liking. Good luck! Ride safely.
Buffeting is when you are in a long ride and you stop at every buffet you find to munch something. :yeahsmile:
Or, it is the turbulence you feel on your head. A windshield may or may not help and some times you need to add lowers too, it depends on the motorcycle and how the wind flows. Helmet type will have an effect but not s much as windshield and lowers.
6'2 here and the Tall Parabellum was the best windscreen i used but it is big but it works great....
IMG_1222 by weljo2001, on Flickr
600_106935832 by weljo2001, on Flickr
I'm using a Stock/Givi combo now. drilled 2 extra holes in both screens turned stock screen upside down and mounted. Works well and looks good. The Tall Parabellum worked better though..
IMG_0519 by weljo2001, on Flickr
I am using an MRA screen with the adjustable wing on the top. I am 6" and I still get some buffeting. So I had to modify the bottom to raise it up a bit. I got some metal pieces and made it higher.
A slight improvement from standard. Cheers.
I'm 6'9", run stock everything and the only time buffeting gets uncomfortable with me is above 75 mph. But in Texas, with everything being so danged far apart, and with high speed limits, that's more often than you might think!
I removed the stock screen and no buffeting. On a long highway ride i'll put it back on because it does take some wind pressure off the chest, but I prefer riding naked.
Doesn't the chapping become excessive?
How do you deal with the staring & laughter? :stickpoke:
I am 6' 2" and I use the givi. It is a definite improvement over the stocker but will not eliminate all the wind hitting your head. It does really help reducing wind on your torso and really reduces fatigue from that. Helmets can make a huge difference in sound, buffeting etc. Buy at least a couple to try.
Discussion Starter #15
Thanks to all for the great advice
Thanks to everyone who replied with advice and knowledge re: buffeting. All is very helpful!
I'm 6'3" with the stock screen at the highest setting. No buffeting of the head at any speed; however, I get tons of torso buffeting at +50 mph. Do I just need a taller/wider shield? Or would riding "naked" help, considering I'll put salve on to stop the chaffing! :)
Seeing as we are about the same height you would likely benefit from the givi. I didn't have any buffeting on my head from the stock screen but could definitely notice issues with my torso and especially fatigue after riding for a while. The givi should greatly reduce the torso issues for you and you can even loosen your grip as you won't feel like you are being ripped off the bike at speed.:goodluck:
I can't speak to the GiVi screen, but for my modded Yamaha Majesty scooter-screen I find that having it tilted towards me a bit (I look over it about 4" or so), on my Madstad brackets, works as I have very little or no buffeting. I'm about 5'10" w/ 32" inseam. Here's a pic of the set-up.
Thanks 4DA NXS and fasteddie. I'll let you know what I try. My first effort may be trying the shield upside down like I've read on other forums, only because that won't cost me anything.
1 - 20 of 21 Posts
