1 - 20 of 144 Posts
Hi.
Have somebody saw that the new Pirelli Scorpion Trail has the same sizes and ranges that the originals tyres of our Versys?
Have somebody ride with it?
http://www.pirelli.com/tyre/ww/en/motorcycle/sheet/scorpion_trail.html
Here in Spain we can't to put tyres with diferents sizes and ranges and this is the better option that I've saw? I think is a good option to do light off-road and good for on-road.
What do you think about it and what's your opinion?
I like the look of them and the way they are described, with mostly road use with a little light trail or off road, seems to fit my needs perfectly.
Thanks for posting. I'll watch this with interest to see if anyone has actually tried them and I'll maybe look into having a set fitted as mine are ready for changing anyway.
by the way, what's 'new' about these? The video tab shows a launch date of 2008! Is it that the Versys sizes are now only just available?
The video is old. In 2008 doesn't exist these tyres with this sizes and ranges for our Versys, it's available from a little time ago.
Sure that this news sizes and ranges is because now there are more dual-bikes with the tyres like Versys: Ducati Miltistrada, etc.. and supermotards wich its owner wants to ride in dirty roads like Yamaha XT 600 X, Aprilia Dorsoduro, etc...
Italians?????? Pirelli, Ducati, etc... ?????
I've had good luck with distanzias and Metzler Tourances. The Tourance I put on my rear seems like it will out distance the distanzias, so I think I'll be going with Tourances front and rear next time. Unfortunately, apparently Spain won't let you run the 150 tourance rear, so good luck with the Pirrellis.
The problem with the Avon Distazia is that there isn't with index of load and speed for the Versys
Front Versys 58W Distanzia 58V
Rear Versys 69 W Distanzia 69V
and here if you haven't the right tyres the police can to put you a good bill and when you must pass the technical inspection you must change the tyres because the index isn't legal for the Versys.:(
DAMMIT, just orderd the sync's:(
I don't think the 160/60 has been produced yet. They have listed it on their 'world' or euro site for some time, but I have never found any for sale here in the states. I called Pirelli USA customer service to inquire and they said it may be introduced at the Chicago manufacturers show if it comes out. Like maybe next year. The show is Feb or Mar I think.
For the OP, check out our tire thread in technical discussion - lots of tire info, quotes from riders, etc.
If you can get a scorp trail in 160/60 I would definitely go that way. Purported to be an excellent 95/5 tire. And yes, found on the new multistrada, F800GS, and Triumph Tiger 800.
We know you can get the tire in 120/70 and 150/70. So if you don't mind a little skinnier tire on the rear they would be worth a try.
The Distanzia is another one with size issues. The 160/60 is a sumo compound and can go away in a few hundred miles. Some have said up to 2-3K. The front in 120/70 is also sumo, but our bikes are light enough that wear seems to be okay for the front. There is also a 150/70 and it's a dual sport compound which should wear pretty good - 4-6K miles maybe? Again, if you're okay with a little smaller rear tire. As far as that goes, if you're willing to run a 150/70 there are quite a few rears to choose from, lots of bikes with that size tire. However very few with a matching front in 120/70. As far as performance, they get mediocre reviews for road and dirt. It's not so great either place. The sumo guys seem to like them, the bimmer guys don't. Therein lies your destiny with them. At least one rider mentioned that the scorp trails worked better on and offroad. Personally I'm not a huge fan of anything British, and I'm a Scot. :D
There's a LOT of data and rider reports, combinations, etc, on our tire thread.
That's tough love...in Spain. We I wish they did come out with the distanzia with a more durable compound I have them and only have 500 miles. No issues yet. Nice tire for Seattle weather.
I can recommend the Scorpian Syncs, great grip on the road and a worth while improvement over my previous Metzlers Z6's off road.
Scorpion Trail wear update
I have put 4125 miles on my Scorpion Trail tires to date. It looks like I'll get at least another 4000 out of them-maybe more. I couldn't be more pleased. Dry or wet-they stick. They do a good job in the dirt/gravel too. These will be my next tires for sure. Photos attached.
Motorcycle-Superstore
Scorpion Trail Dual Sport Rear Tire
Size - 150/70V-17 G--$150.99
Scorpion Trail Dual Sport Front Tire
Size - 120/70R-17--$125.99
Mr Miyagi
Any noticeable difference / issues with going with the narrower 150/70 on the rear vs a 160/60??
I run a Continental Trail Attack 150/70 rear (Compatible with Versys 4.5" wide rim) with Avon Distanzia 120/70 front. They feel excellent in all conditions, with no issues or complaints whatsoever. 'In service' (inflated) overall width is 159 mm compared to 172 mm for a 160/60-17 street tire. 'In service' overall diameter is 656 mm (+2.82% gearing) compared to 638 mm for 160/60-17 street tire.
Scorpion Trail 150/70 is at only 149 mm width, with a taller diameter of 667 mm (+5.85% in gearing). It's about equivalent to going from stock 15/46 sprockets to 15/43.5.
Thanks for the info Invader. The engineer in me tells me that mixing tire brands is not quite right, but many seem to be doing it with no issues, including yourself. Taken to an extreme, I suppose, two very different tires (front and rear) with very different grip characteristics could have you losing one end well in advance of the other - not good...
1 - 20 of 144 Posts
