21 - 36 of 36 Posts
Discussion Starter #21
Thanks guys! She's safe home in my garage - ended up trailering because I couldn't get a ride. Which oil filter do you guys recommend if not OEM?
Question for you guys - I'm riding it home, it's about a 3.5 hour ride. Engine only has 165 miles on it. Should I be concerned about RPM limits and/or running the engine too long at the same speed??
When shop bring V650 to my house they told me first 800km ride no more than 6000 RPM, second 800km no more than 8000rpm. Manual say first 800 no more than 4000 rpm, second 800km no more than 6000rpm. So I use middle first 800 no more than 5000 rpm second 800 no more than 7000 rpm.
For oil filter - I will always use OEM because it is OEM and cheap (or until service guy recomended me something else), it cost im only 13-14$ (including tax.)
For oil - I run on Motorex 15W50
Discussion Starter #23
Just a little update on my mods! Love this bike.
Shoodaben ECU flash
Annitori Pro V2 quickshifter
Givi Airflow windscreen, modified and tilted back
Windscreen spoiler
Seat Concepts seat in carbon fiber
Front fender reflector delete
Pannier reflector delete
Rear tire hugger
Ambient temp and voltage meter in dash
16T countershaft sprocket
XPEL Ultimate clear tank protection
Koso heated grips
VLEDs 6" white LED bars mounted in lower vents
VLEDs 6" red LED bar as auxiliary brake light
VLEDs 3" amber LED bars mounted inside stock signals
Front turn signal backing plates removed
LED flasher relay
Custom wiring harness with 3 relays
Heated gear wiring harness
Heated gear permanent knob on dash
Flash-to-pass garage door opener
Marco Tornado air horn, separated
Black brake and clutch levers
Front fender extender
Black powder-coated fairing bolts
Suzuki rear axle nut (no more castle nut/cotter pin)
Hepco & Becker Daypack
Comie top case with Givi support arms, Morimoto 5top LED
Motowerk bar risers
Motowerk peg lowering kit with brake lever nut
Motowerk mirror extenders
Custom headlight build:
  • 2.0 inch projectors, dual low-beam and dual high-beam function
  • Black shrouds
  • Motoholder bulb holders
  • 5000k 35W HID kit, 4-wire pass throughs
  • satin black painted interior
  • LED corner accent lights
  • MotoCycle relay harness
  • Sealed with black retrorubber butyl
Nice mods, please can you tell me what you use for ambient temperature?
I try to find something, but I don't know what to choose.
And which fender extender you use.
Discussion Starter #29
Yep! This fits perfectly in the stock accessory spot, no cutting required:
I got mine off Ebay. Only reads Celsius. I'm learning that mid to upper teens is good riding weather. Haha
Discussion Starter #31
Oh ha nice. Yeah I ride down to about 28ish Fahrenheit. I love the metric system but can't stand Celsius
...I love the metric system but can't stand Celsius
Me too! One degree C is TOO coarse, compared w/ F.
1 degree C = 1.8 degrees F
WHAT I posted was HOW MUCH a 1 degree CHANGE (Celsius) is in F, NOT how much 1C IS in F.
My bad,
I got lost in translation in original post.
I found on the internet what exactly you were talking about :)
Gotta love metric for tools n bolts n such. Makes it soooo easy to figure out. None of that 3/8 or 7/16 bullsh!t.
21 - 36 of 36 Posts
