1 - 20 of 25 Posts
Hi All,
I have a new 2017 650LT Versys. When I bought the bike I got a super discount on all the parts I wanted since the dealer lost track of my panniers and had to ship them to me later.
I have the following parts and I'm going to get them installed shortly:
Kawasaki Heated Grips
Kawasaki Hand Guard Brackets
Kawasaki Fog Lights and on off button
Kawasaki Right and Left 12V power outlets on right and left of my dash with relay (my dash has the gear indicator on the LCD board)
Questions:
1) Does this have to be done at a Kawasaki dealership or do I void my warranty?
2) What should I be concerned about when getting this done?
3) Does anyone know if for my bike a right and left 12V power plug will be okay? Seems the right side should have a gear indicator but I have the gear indicator in my LCD so ...?
4) One dealer is quoting 3-4 hours at $109/hr our $436 Labor. Seems reasonable. Any of your thoughts welcome.
5) Still haven't found a good after market windshield?
Thanks for any of your thoughts.
Honestly, all of these installations are relatively easy, and you’ll learn a lot about the bike. Save the $436 and use it for gas money. When you get the panniers off, you'll have easy access to install the lights,sockets, and hand grips.
I think there is only one plug available for the 12V outlets. I’d tap one into the wires of the other. 5 Amp max load on the relay, though.
If you feel the labor charge is reasonable and you have confidence in the dealer to do everything correctly and you aren't comfortable with digging into your new bike, then perhaps the best answer it let the dealer do it. If they make any mistakes it's their responsibility to make things right. I'm not going to say you will, but if you do make any mistakes, it's your dime. My two cents only.
Shows more about the relay but not in English..
A coupla notes.
1)
The Kawasaki grip heaters suck. Complaints on uneven heat for one. Do a forum search.
I use Heat Demons with a PWM controller, others like Oxfords. The Heat Demons have coils that go under the grips so make sure you like the grips you have. I picked up these grips:
https://www.murphskits.com/product_info.php?products_id=35
These grips also utilize a higher output heater for the clutch side as it's directly attached to handlebar metal. Good stuff.
2) The power outlet location leaves very little clearance for cords with the hand guards installed. Do make sure you have clearance with whatever you plug in. Larger plugs will interfere. Risers may eliminate the issue, but I don't use them.
Have fun and enjoy. Welcome aboard.
ttfn
I'd agree with Arion...................if you're handy with tools then go for it and save some bucks, but if you're not handy then let the dealer do it.
Ditto. easy installs. you can find USB charge ports that fit the round cut outs in the dash on Amazon and ebay. I used this one: https://www.amazon.com/gp/product/B00LOAAUIM/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Just in case you want 12V on one side and USB on other. save the $436 labor, order the service manual and easy stuff to do your self. Enjoy!!
A coupla notes.
1)
ttfn
Personally I would return the Kawasaki heated grips and get your money back, I have the Oxfords, and thousands have them, the ones Weljoe has came out just recently and really good feedback on them. What has been said about the Kawasaki grips is 100% true, they suck, and I was quoted something like $200, my Oxfords were half of that and from my dealer.
As to installing, good learning experience, however you make a mistake, it gets very expensive. Lots of support on this forum for DIYS , however , only you know your capabilities. The quote if you have used these guys, is very reasonable, as a professional, I would be hard pressed to complete all that in 3 hours, if they are quoting time and material, look out, as you may be paying for 6 hours, which is what I think it could take.
Reactions: Beezerboy
I seem to be in the minority when it comes to Oxford heated grips, so go where your gut leads you. But, my Oxfords are hot on the right side and lukewarm the left. I have read on other forums that Oxford had a problem with there heat control unit on some sets. Your results may vary. Personally, the Koso Apollo grips suggested by Weljo are a much cleaner install.
The power port installation is relatively easy because the 4 wire connector is right in front, under the dash. I used the cigarette lighter style socket in the LH hole and wired it into the 'always hot' circuit which allows me to easily use my battery tender with the cigarette lighter plug. I used a dual USB socket in the RH hole and wired it into the 'accessory' circuit. If you have a voltmeter and some wire and spade terminals, it's quite easy to 'tie into' the 4 wire female connector.
Discussion Starter · #12 ·
Uneven heating in Kawasaki OEM Grips for Versys 650LT
I just had the OEM Kawasaki Heated Grips installed on my Versys 650LT. I rode them hold in chilly weather and found that the left hand worked fine and was heated but the throttle grip is only 25% as warm. At full heat one the left is hot and the right is lightly warming so it really won't work out for my burning left hand and under warmed.
Does anyone know if you can adjust the power from right to left to get it even?
If not can I send the Kawasaki product back for poor performance and get a refund?
Is there a product that allows to manage the left to right heat to get it even or a new product that seems to have overcome this uneven heating discrepancy as of Jan 2018?
Thanks all, Mark
I've see this as a common report with the OEM heated grips, seems that it may have to do with the plastic under the throttle side. Heard good reviews for Oxford grips.
Sent from my TF201T using Tapatalk
I use the Heat Demon under grip heating coils. They have different size coils for each side that work well with the unequal heating demands for each side.
Check your warranty to be sure, I went through my own and found that personal modification does not void the warranty, unless involved in an incident where the cause is ruled to be because of a modification installed by a non - Kawasaki tech.
I agree with the sentiment that if you got a spare couple of hours and want to learn more about your bike (and I believe you should), installing accessories is a pretty easy thing to do and you can't do any harm since the manufacturer already provides all the necessary electrical ports. You just need to use them without having to mess about with electronics. I installed my 12V accessory without any prior experience and did just fine, and I learned more about what lies 'under the hood'. It even came with the instructions with pictures and all, in the little green Kawa box.
However, if you decide to install the 12V accessories yourself just make sure not to break any plastic penises while removing fairing cuz they're not the most resilient things. I usually tend to throw a bit of WD-40 on the rubber vaginas before reinstalling fairing, then they go in smooth. (yes, that sounded weird lol)
You may want to consider using spray silicon lube as petroleum solvents tend to not be kind to things rubber and plastic over time.
...However, if you decide to install the 12V accessories yourself just make sure not to break any plastic penises while removing fairing cuz they're not the most resilient things. I usually tend to throw a bit of WD-40 on the rubber vaginas before reinstalling fairing, then they go in smooth. (yes, that sounded weird lol)
I do that TOO. Makes the job way easier.
WD40 was tested for O-rings (by MOTORCYCLIST magazine) where they left some O-rings in a container of WD40 for several days, w/ NO problem or deterioration.
:clap:
A coupla notes.
1) The Kawasaki grip heaters suck. Complaints on uneven heat for one. Do a forum search.
ttfn
Can't speak to Heat Demon heated grips, but I will wholeheartedly agree that the OEM grips are hopeless.
I spent the $$$ and wish I hadn't. Don't be THAT guy.
1 - 20 of 25 Posts
