1 - 11 of 11 Posts
You're all sickos
image hosting over 10mb
The ramps I had were way too steep, so I used some plywood on an extendable ladder and it worked just fine
I miss the old single motorcycle trailer I had. Some day I'm going to get an enclosed trailer or a toy hauler camper
I see it wasn't a tight fit. No lube or elbow grease to ease it in was needed.
Once I had her in my sights I rammed it right in there
What a topic title! LOL!
have you looked at the shark cage? If I was going to haul frequently I would get one. Way to many fail videos out there when trying to load bikes with makeshift or incorrect ramps for the job.
Never heard of the shark cage, I'll have to look it up
This was only to take it to the dealer. As much as I'd like to take it on trips I can't because I have a 5th wheel non toy hauler so there's no room. And when I go someplace it's always to go camping so bike trips aren't in my immediate future
And I have watched a ton of those fail vids....and learned from them
I bought one of these from Harbor-Freight:
http://www.harborfreight.com/870-lb-capacity-40-inch-x-49-inch-heavy-duty-utility-trailer-with-8-inch-wheels-and-tires-42708.html
I moved the axle rearward when I was trailering my '09 from AZ to Canada, but then moved it back to the stock location, as that had been TOO far back (too much tongue weight). I added a spare wheel, etc, but it COULD use a longer draw-bar.
Very neet setup FastEddie !!!
Any fear that it would tip over ?
LOP
I had a trailer when I had my gixxer. You could stand it upright when not in use, which ended up being maybe 6x3 ground space by 8 feet tall. Of course I didn't like the exposure to the elements but it was ridiculously easy to load and strap down
...I moved the axle rearward when I was trailering my '09 from AZ to Canada, but then moved it back to the stock location, as that had been TOO far back (too much tongue weight). I added a spare wheel, etc, but it COULD use a longer draw-bar.
I used it w/ the axle moved back to the stock location to tow the GREEN HORNET to Kelowna from near Calgary, three years back. Worked FINE!!!
LOP
Nope.
IF you want one Phil, head to New York state to the nearest H-F, and get one. Takes a few hours to bolt together, and the two boxes should fit into pretty much anything (they fit inside the Nissan Maxima in the pics, pulling the trailer).
Nope.
Very tempting ... Just have to find a way to go true customs ... (so far, I don't have a passeport, a nexus card, or an ''enhanced Provincial Drivers License '')
Thank's Eddie
LOP
1 - 11 of 11 Posts
