1 - 20 of 25 Posts
I have a leak on the bottom back portion of the exhaust cannister.You can hear it and feel the air on your hand.I think it's at the weld.Going to dealer tommorrow.I haven't hit anything I'm aware of and haven't gone off pavement.Under 4k and less than 3 months old.I have outstanding dealer support so I don't have to worry.
It is a drain hole.This is my first muffler that has a built in air leak.Is this normal?I may be learning something new.have a great day
My kawasaki dealer thinks the drain hole on the muffler does leak exhaust air,He has a call into kawasaki to verify.Does anyone know if this is correct?thanks.
Keith
The muffler drain hole is in fact also a path to the inner muffler where pressurized exhaust gasses are released, as well as accumulated water which is a normal by-product of gasoline combustion.
The muffler drain hole is in fact also a path to the inner muffler where pressurized exhaust gasses are released, as well as accumulated water which is a normal by-product of gasoline combustion.[/QUOTE
It is normal for exhaust air to come out of this hole?The hole is there so water will have a place to drain?I want to make sure that it is normal to have exhuast air coming out of this hole.I have never seen another muffler on any kind of gasoline vehickle that had a drain hole that released exhaust air.Have a great day to all.
Keith
Am I the only one who is bothered by an exhaust hole ?Are there other vehicles on the road that have this feature?The funny part is I did not hear this air escaping until I had the bike for a few months.I,m almost sure that this hole was plugged up when I bought the bike.I,m behind the times for sure.have a great day.
You can hear it? How about a picture of the hole. My DRZ had a drain hole as well. I'm sure there are plenty that do. But maybe you have something else going on. Does the hole look machined, like it's supposed to be there?
Yeah, well said Bear... All car and truck mufflers also have a water drain hole, where some exhaust gas pulses do inevitably escape. But if the hole doesn't look right, I'd like to see a pic of it too.
The hole(maybe 3mm perfectly round) looks like it is supposed to be there.Some new v bikes I looked have the same hole but I can't hear them run..A few days ago I started my bike and heard an exhaust leak.When I held my hand under the muffler I could feel air escaping.I can put my finger over the hole and the sound stops,so I know this is the source of the leak sound.It's not very loud.I still don't understand why I did not hear this beforeThis is my first bike that has a hole in the muffler that exhaust air comes out.I ride daily.I took the bike to the dealer and he also heard the leak when the bike was started.A call was put into kawaski,but no reply yet.I have a feeling I am not up to date.I've seen plenty of bikes spit steam and mist when started,I understand the theory of why the hole may be there.MY old school thinking is exhaust leaks are bad.If all versys blow air from the hole then I don't have anything to be concerned with and I need to learn something new.
Keith
And be thankful your hearing is so good!
:D
If it were me, I would carefully inspect around the exhaust joints to make sure nothing is loose. If I found nothing, other than the weep hole, I'd ride it without a second thought.
So all V's blow exhaust out the weep hole?I wasn't sure if there was an outer casing,or that this hole was in fact going into the muffler itself.My first bike with a purpose made hole in it's muffler.
Discussion Starter #14
I plugged the little hole,water vapor is just going to have to use the big hole.Sounds much better and I am not so fixated over a tiny exhaust leak.:)
Keith
The internals are not all made of stainless steel. With the drain hole plugged, water will accumulate within, and your muffler/catalytic converter won't last long...
I'll take the chance that heat will turn any water into steam.That is a good picture of muffler internals.My original guess was that the hole was in a confined area of the muffler case that did not have exhaust flow but was subject to water collecting.The exhaust was blowing out the hole because something was wrong.But since everyone else can feel air blowing out of the hole I see that I'm wrong.The hole is in the baffle area where the gasses are flowing.Every Versys does blow air out of this hole?..This question I haven't seen answered,I assume it does?..Thanks to all for input.
I used high temp silicone.Don't know how long it'll last but I will hear it when it falls out.
keith
1 - 20 of 25 Posts
