1 - 20 of 22 Posts
First I am a big guy. Second I had the scoot loaded pretty good but well within capacity.
My scoot has a pc3, 43tooth sprocket and a full arrow exhaust. When I ride the back roads and gravel roads I usually get 40-44ish. But as a rule I get approx. 40 mpg on a day to day basis. Between Friday night and yesterday I put just shy of 900 interstate miles on. I used all three grades of gas and used the throttle lock. I basically rode I80 East to West and then back through Iowa. So the wind issue should be some what negated.
I varied my speed on different tanks for the entire tank. Any where from 65 to 85mph. I got between 29 and 33 consistently. My gps show 103 miles for every 100 on the odo. and 2 mph lower than the speedo. The math was done in my head so the mpg were not exact but I work with numbers a lot so they better be close. As far as I know I have the original plugs. I bought the scoot with 2500 miles on it and it now has five something (with out looking). I keep seeing these posts with all the high MPG's listed while riding high speed. I have cleaned the air filter (was not dirty), tires were 2psi over book. Now I am not trying to get 100 mpg. but 40 to 45 on the hwy sure would beat the crap out of 29-33. I also have Mikes touring shield.
Help me out.
What do I have wrong besides the weight thing.
Thanks,
Bob
Maybe the PC3 is tuned REALLY Pig-Rich and tapers off too late?!
I have seen this in cars a time or two, where the tuner tries to incorporate some safety into the tune (for turbo cars) and ends up stiffling power instead of finding a balance.
My stock tune and exhaust '09 V gets about 45 mpg consistently with my 44t and a stock windscreen. I just installed my Mike's GT Touring and I better not see 30 something mpg!! :stickpoke:
Also, I weigh ~240lb + gear and the V46 top case...
Well it is supposed to have the suggested programming for the full arrow exhaust. I guess I need to hook it up and make sure it does. I wonder if I could just unhook the pc3 and run a tank through it and see what happens. Seems to me someone wrote on here that it would make it too lean and damage the valves or some thing. Ok time to read the dyno jet book.
Thanks for the reply.
I will post what I find out.
I get 40-45 mpg. Have a large windscreen, Givi hardbags and top case, cruise at about 70-75 mph. my weight is 175. Funny thing, my last 4 bikes, all different displacements all have gotten about the same mileage. Guess its alot about how you ride. I would suspect the new black box going rich tho in this case. Better than lean tho so you din't go BOOM.
Well that was easy. The map on the scoot matches the suggested map perfectly. M228-003. If I remember correctly @70 mph it was approx. 5100 rpm. looking at the map it seems to me that they are adding a lot of fuel in this range. I have no idea about the percent of throttle. Does any yone know if I can safely dial this down without doing any harm?
Thanks,
Bob
Thanks dwr302 for the reply. I am a slow typist. Please see post above this one.
Tinner
You probably don't need any more comparison data, but here's mine anyway: I've got a stock 09 V, 1800 miles, MikeShields GT screen. I ride mostly back roads in western NJ at 40-60 mph, with occasional runs down I-78 at 65-85 mph. I don't know whether I get better mileage at higher speed on the interstate, but I'd guess not. On the backroads, I keep rpm in the 4000-6000 most of the time, in 4th or 5th gear. On the interstate, I'm in 6th gear running 6000-8000 (whatever it takes to keep up with traffic and not get run over by the trucks).
With all that, I get 50 mpg most of the time. As much as 51.4. Once 49.8.
I read once that best mileage from an engine viewpoint was at max torque rpm. If you're running much higher rpm than that, then mileage probably suffers.
Perhaps someone on the forum can give data on their mileage when running mostly at 80 mph or so.
Thanks scottyneal,
I think I am going to remove the pc3 and the Arrow exhaust and see what a stock setup does. I will leave the 43 tooth on as it should only help the mpg.
Have a Great evening.
I don't have a PC or aftermarket exhaust, but here is something to compare to when you go back to stock configuration.
I did 350 miles on Friday, mostly, on some of the twistiest roads around here (Mt. St. Helens loop), so other than on any longish straight where I short shift, it's spinning at about 7K RPM and wide open throttle coming out of the curves. Stock engine with a 16T CS sprocket, upside-down OE windshield and no bags installed - averaged 50 MPG.
Gustavo
Thanks,
Bob
I won't say one way or the other without hard data like a wideband A/F meter or something. If you were to make a one or two point change in the 20 and 40% columns below 4000, I think you would be safe. Its when you really start getting on it, like over 6K, when Air Fuel Ratios (AFR) will be super crucial due to timing being advanced....
dwr302 said it best though.... it may about how you drive...possibly. I can get about 26 mpg in my 4000lb, 300hp car if I drive it nice! :devil:
Also, I have been looking for an Arrow/PC3 kit so let me know if you decide to go another route in the future! Hope you get it working to your liking as is though!
Thanks,
Bob
That is a hell of a lot of fuel added at 10 to 40% throttle opening, above 4000 rpm as when you're cruising the freeway. That +34% fuel at 20% throttle and 6000 rpm for example surely has a substantial impact on mpg, beside the upright mounted Mike's touring shield... I leaned back my 16.5" tall Mike's shield as much as I could by cutting the brackets, which also cured the buffeting.
I was getting in the mid 40s at 22,000 miles. After having my valves adjusted it looks like I am back into the 50s. The engine revs smoother now. Could valves that were too tight reduce gas mileage.
Just posted 52 with mostly highway and 30% stop and go - 7k on the bike, large windscreen and saddles. Highway speed mostly 70 (posted 74, 75)...I do put in 93 octane however (to try and offset the **** ethanol additives)
Discussion Starter #14
Gustavo
It has been a while since I have looked at the ratio charts but isn't that 16 tooth about the same as dropping two in the rear? What do you have on the back? How do you like the height of the gearing?
Thanks,
Bob
Discussion Starter #15
Also, I have been looking for an Arrow/PC3 kit so let me know if you decide to go another route in the future! Hope you get it working to your liking as is though![/QUOTE]
Part of post removed by me.
That is why I kept the throttle lock on. There was very little twisting of the throttle except while getting on the I from the on ramp.
It has been my plan from day one to remove both of these items before my trip to Ak. next year. I have just been having waaaayyyyy to much fun with this little scoot. Kind of re living my child hood days. :)
This weekend has been the first interstate riding I have done with it and I am just totally taken back by the mpg.
Before you go and buy any where else we will need to talk. :)
Discussion Starter #16
That is a hell of a lot of fuel added at 10 to 40% throttle opening, above 4000 rpm as when you're cruising the freeway. That +34% fuel at 20% throttle and 6000 rpm for example surely has a substantial impact on mpg, beside the upright mounted Mike's touring shield... I leaned back my 16.5" tall Mike's shield as much as I could bu cutting the brackets, which also cured the buffeting.
That is exactly what I am talking about. 34% more than the OEM. Holy Moly. But i do not have a clue as to where my throttle is at that time. I have not noticed any buffeting with my shield.
Discussion Starter #17
I am sorry! I do not know the answer to this but my guess is yes it could simply because of the delay in opening.
But I can sell you some oil that would oh never mind...lol
Have a great night!
Discussion Starter #18
I can only think of two words.
"bite me" lol I am both kidding and jealous. Ethanol sucks and I avoid it like the plague. How ever I think in Ia. it is all at least 10%. That is only my thinking and it could be mistaken.
Have a Great night.
I continue to get good mileage from the bike. The fueling is spot on. Doesn't run lean, doesn't overheat, smooth power from idle to 8000rpm (after than it starts to fall off).
I suppose one might get a few more ponies out of the engine if it were tweaked a bit, but I wouldn't expect more than 4 or 5 horse gain with a slip on and a PowerCommander (at the very most).
I'm inclined to leave mine stock, twist the throttle to the stop, and ride it like a stole it. :)
Tinner,
I average about 44-46 riding around here, bit will actually be heading to Westby on friday the 2nd, stopping at the Rod&Gun :):cheers:
Will be leaving on Saturday to drive back even thought the ex-brother in law wants me to stay a day, little uncomfortable, but i've got other made plans and don't want to be traveling on the 4th.
I'll be on a fast green one!!:thumb:
1 - 20 of 22 Posts
