1 - 14 of 14 Posts
let's see if this works. got some help from the mods on how to post pics.
front end mods include teflon brake lines, fork revalve, and fenda extenda.
http://www.flickr.com/photos/[email protected]/6743607309/
givi windscreen with a vario wing. windscreen has 20mm cut off the top to flatten it out. windscreen brackets are shorter and angled back
http://www.flickr.com/photos/[email protected]/6743608949/
protaper ATV mid handlebars with crossbar removed, gps mount on bar riser cap
http://www.flickr.com/photos/[email protected]/6743610949/
shadetree radiator guard, gxsr crash bungs, office depot inbox radiator screen
http://www.flickr.com/photos/[email protected]/6743612837/
perforated metal skid plate
http://www.flickr.com/photos/[email protected]/6743614209/
micron muk-63 EU muffler with guard removed
http://www.flickr.com/photos/[email protected]/6743615693/
elka shock
http://www.flickr.com/photos/[email protected]/6743617465/
tail trim and mini turn sigs
http://www.flickr.com/photos/[email protected]/6743618737/
flat black hugger, rear pass peg eliminators
http://www.flickr.com/photos/[email protected]/6743620219/
carpenter ants got to the chainguard, -1 on the chainwheel, spools
http://www.flickr.com/photos/[email protected]/6743621727/
voltage reg aluminum mounting plate/heatsink
http://www.flickr.com/photos/[email protected]/6743623079/
EX500 pegs, oversize kickstand foot
http://www.flickr.com/photos/[email protected]/6743624423/
voltmeter on left, aquarium thermometer on right, 1/8" mini plug for gps power on lower right, heated grips switch on lower left
http://www.flickr.com/photos/[email protected]/6743626005/
seat foam mod with marine vinyl top
http://www.flickr.com/photos/[email protected]/6743627741/
no pic of the pcV or the zip tie on the throttle sleeve cuz it's hidden :yeahsmile:
the vario wing is the vta4. yes, it works great. low position is steady windblast similar to no screen, hi position is greatly reduced. screen is in #2 position, I'm 5'10", arai helmet.
I'd rather have the controls bend in a crash so I could hopefully bend them back and get home. had that happen enough times on other bikes. the chainguard I drilled just for you.
Removed radiator covers, drilled chainguard and drilled gear shift lever? :eek:
Your rear brake's steel braided line is wearing into your swingarm?
1 - 14 of 14 Posts
