1 - 4 of 4 Posts
Last weekend I installed some farkles on my bike, including the OEM hand guards. My bike had the fairing buzz since day one, but during the test ride I noticed a pretty terrible buzz at 4K rpms that was not present before. After some time I figured out that this new buzz was caused by the bar end weights, they could move a bit. Used a hot glue gun and that took care of it.
But while I was doing that, I had noticed that the right fairing and the side black unpainted panel, the one that goes all the way back to the seat, had a bit of free play, the tabs that insert into the side fairing were a lose fit, and I could see some white dust (plastic being worn due to friction). I used some double sided tape to glue it to the fairing, and then some small pieces of plastic in between the tabs, to make for a tighter fit. I did it just because I didn't want the tabs on the fairing to wear, not because I ever thought this could be where the buzz came from...
But when I took it for a test ride, it was fantastic, the fairing buzz that had been there since I rode it out from the stealership was gone!
On my 2010 the fairing buzz was caused by the plastic that goes around the headlight, so I always assumed that the fairing buzz would come from a similar place on my 2014...
My buzzing came from the original handguards, completely disappeared upon removal. With winter on the horizon I shall need them again so some "playing around" with is needed.
1 - 4 of 4 Posts
