1 - 5 of 5 Posts
Hi, this is on my 2018 versys 650, anbody have on one side welded steel and on another side that steel don't existe? On picture, on right side you can see under wire for opening seat some welded steel plate, and on left side on picture that plate don'r existe. Is that normal, and that plate is only for saftey so nodoby can cut that line. Or my bike have missing part?
Administrator
2015 Versys 650 ABS / Helmet ? Cargo Net
FYI the original post is taken in a area with the plastic, why the seat release area was circled is beyond me, as to the other side, the same, parts are welded on for other purposes as are holes drilled, some holes are pressure relief holes for welding, some brackets are to do with the jig and welding. Since a discussion about helmet hooks, I thought I would post my 2015.
Two Hooks for two helmets
My cargo net, yes a first time for everything, I love it!!
I just looked at my 2015 V650 and there isn't that piece on either side. It doesn't look structural on yours, so I wouldn't worry about it missing from the other side.
1 - 5 of 5 Posts
