1 - 18 of 18 Posts
Ok, narrowed tire choice down to two, PR 2 and BT-023.
I have read reviews/opinions from other forums and the manufacturers, which is how I came to these.
Since different bikes can handle differently on the same tire I am trying to find out who has run either of these tires on their Versys and what you think about them.
I am looking for personal experience from you guys to help in my decision such as handling on wet roads, cold weather, cornering, mileage, feedback, turn in, stability, etc.
Thanks.
:feedback:
After getting a flat on the stock Dunlop (4 flat tires in 40 years of riding and all of them were on Dunlops) I switched to the 023's after reading about them in the English Biker mag and talking to fellow riders. The ride is smoother, better bump absorption, and turn-in seemed a little slower but has gotten better with some more miles. Only have had them for 900 miles, but a friend has them on his FJR and has about 7500 miles and still has tread left, and those bikes eat tires. Definately a great tire in the wet and would recommend them with the new Conti's a close second.
I have the Michelins - very happy with them so far, great grip in the dry, not tried them in the wet yet but have high hopes for them too.
Something tells me that might be today from the look of the forecast.:(
I´m not too techie so can´t give you a better run down unfortunately, but someone else better than me will be along shortly.
Most tires do very well these days, especially the big name brands. I've had the PR2's on three bikes now, though not the V, and they have been excellent. Highly recommended. Having said that, I'm sure the 023's are excellent, as well. Find a good tire you like, at a good price, and run w/it. Free advice.
I run PR2's on my Speed Triple, best tires I have ever had on her, stick in all conditions great in rain. I am also getting more life out of them than anything else I shod her with.
Note they are longer to scuff in, about 500 to get the stick, but once they do...:D:D:D:D:D
I like the Michelins PR2's way better than the stock Dunlops. The Versys is the second m/c I've used the PR2's on and it's helped both handle better. In Sept, the group I ride with annually went out for our usual ride in the Pacific NW. This year was through WA, into BC, down into ID and MT, back through WA to the Puget Sound. Five and 1/2 days, with 4 of it in (and out of) the rain. The PR2's were great..............frog
Thanks for all the feedback guys. It seems the Michelins might be the way to go.
Has anyone had any grip issues in cold weather (30's to low 40's) with either tire?
Somewhere around 38 degrees is probably going to be my cutoff for riding.
:thanx:
I just did a little riding today, temp was about 36 I have pr2's and they were fine, although I didn't really push them to hard. Also should tell you that I have at least 10500 miles on them.
Thanks glowcat, much appreciated. And excellent mileage BTW. At my rate of riding, those tires would last me about two years, maybe a little more! :D
I'm trying to make the same decision, my 2nd Roadsmart rear is toast, after 5500 miles. I got the same mileage out of the stock rear as I have the Roadsmarts, so I'm going to go with the Michelin, I think. The thing is, I can get the Bridgestone a bit cheaper, but I like the reviews on the Michelin, most gave it 5 stars on mileage. We'll see how it does on these Ozark hills!
Has anyone had any grip issues in cold weather (30's to low 40's) with either tire? Somewhere around 38 degrees is probably going to be my cutoff for riding. :thanx:
Plasma........I've ridden with the pr2's down into the low 40's with no problems. In fact, on that long trip in Sept, we hit some low to mid 40's in light rain going over Lolo Pass on the ID/MT border. This road has lots of curves and we were moving right along and I noticed no problems at all...............Frog
FWIW, I’ve been running (and have gone thru a few sets) of the PR2’s since May. I’m quite happy with the handling (wet & dry) and the mileage hasn’t been too bad: Rears 4,500 to 6,000 | Fronts 7,000 to 9,000 miles (to the wear bars).
One thing to note on the PR2’s. There isn’t a whole lot of rubber left once they reach the wear bars. I used a couple of the rears until they were just balding and when I felt what was left as I changed them it was kinda scary.
I’m just now putting on a set of Metzeler Roadtec Z6’s to try them out for the winter because they have a slightly more aggressive tread and the roads in my area get a fair bit of sand & salt.
The guys on the Concours site swear the PR2's aren't as good as others in the cold, as far as grip. Totally different bike, granted, nevertheless, it's info. Do w/it as you will. Always show a little more care in the cold, regardless of tire.
I had the PR2's on the Versys before putting the Conti's on and liked them. Most likely would have gone with another set, but they weren't available in the sizes I wanted when I needed them, so I put the RoadAttacks on. Also a good tire and did fine this morning at low thirties temps. Harder riding than the PR2s, but considering their price, the trade off isn't too bad...
Discussion Starter #18
Thanks all for the info. Just as I had my mind made up to go with the Michelins:D, I made the fatal error of looking into the RoadAttacks since a couple people had mentioned them. I think I just went back to square one.:(
Seems there is a new RoadAttack2 http://www.conti-online.com/generator/www/de/en/continental/motorcycle/themes/motorcycletires/sport_touring/sport_touring_en.html that is relatively new, like the 023's. From what little I have been able to find on them, they look like they will improve upon the RoadAttacks...similar to the 023's over the 021's.
I have only been able to find them at a local shop and they fall right in line with the PR2's price wise.
And if that isn't enough, I saw that Michelin is coming out with a Pilot Road3. :confused:
http://www.compacc.com/p/Michelin-Pilot-Road-3-Dual-Compound-Tires-Z-Rated-Front
Decision making continues.....:teetertooter:
1 - 18 of 18 Posts
