1 - 14 of 14 Posts
Just fitted Madstaff screen brackets and screen, +10 piece of kit.:thumb:
Here's the photoblog
Chris
Nice install, it's farily simple yeah?!?
Did mine a few weeks ago... one thing I've noticed though, is increased vibration (noise) from that section now, especially between 3 and 4k rpm.
has anyone else noticed this, if so whats the remedy?
Mine seems to have gone away-Will let you know later. I can "see" the shield assebly vibrate now however
Amir - I think I finally isolated the last bit of vibes I had to the madstad bracket & shield, worse on the left side. I ended up tightening the guide bolt on the adjustable part of the bracket. It's the bolt that doesn't have the knob, that you're supposed to leave a little loose to allow the bracket to move up and down, tightening it only with the knob. Only thing was a little loose means that it allows the bracket to vibrate at higher revs. Tightening it down means less adjustability on the fly, but a fair trade for no vibration. Once I work out the ideal screen height and angle for me, I'm not likely to want to adjust it much, so no worries.
dm
I think the bracket is to thin & weak. needs to be made out of a heavier gauge metal.
Have you actually used it to make that statement?
I'm not sure why people are ragging on the Madstad bracket. I have one and am 100% happy with it. While it's true that the original Madstad product had a weakness, Madstad stood by it and added a stiffener. It does exactly what it's supposed to do. Madstad is a good company to do business with and make a quality product.
Yes, I have one with a parabellum shield mounted on it. The stiffner helps , but is not enough. With the bracket adjusted all the way up for height, it will not stay adjusted vertically, and it shakes like crazy.
Okay. I use it with the Givi and it works fine. The Parabellum might be taller than the Givi and that's where the issue is.
The issue is! That the bracket has to much flex,the stiffner is just an attempt at a cheap fix. The bracket is a great idea, it just needs a few improvments.
Staff answer
Works great for me. One neat thing about the
slight vibfration is it reflects the sun in a great
flickering pattern that really lights up the road
signs and alerts oncoming traffic! Love it.
I have a feeling the stability of your specific
windshield has a lot to do with it, plus that
adjustment on the sliders. Love that MadStad -
it's the staff of life, ha ha.
When you put a large shield way up high and near vertical, you turn it into a sail and at some point you're asking for an unreasonable level of performance. If you want that much wind protection, perhaps a naked bike equipped from the factory with a flyscreen isn't the right bike for you. A Gold Wing, perhaps?
Super size me
August; Those large handguards don't interfere?
(What are they anyway???) Can you still get
full range bar motion with any windshield position?
1 - 14 of 14 Posts
