No to your question, I am surprised that good instructions weren't included, Speedy has step by step instruction for his lowering link. One bit of advice, if you have a triple tree front stand I would advise to use it. Other ways are if you have a overhead beam, I have seen someone use the track for the garage door , etc. you need to take the weight off the front wheel, using the handle bars or frame forward of the battery. You can also access the tubing that goes through the frame and use blocking to support the bike. Also can use jack stands under the foot pegs, although you will need to add a bit of counter weight to the rear, foot pegs are forward of the balance point.I'm getting ready to install the SW Motech Lowering kit and have a question.
In raising the front forks, does the front wheel need to come off first?
more complicated than it sounds, follow the instructions, somewhere I have pictures of my 2015. A large 12 inch adjustable or a pair of 10 inch channel lock pliers , even vise grips will work. Most important thing is supporting the front of the bike, also use caution on the left shock. I did it by myself, then a oops, left shock stopped by clutch cable.I have details somewhere here.I get my Versys tomorrow and bought the Speedy lowering kit also last week. Truthfully, this is not really a one-person job to be on the safe side. Having a bike lift and an extra set of hands is what I plan on having next week when I tackle this one. Also, one thing that no one seems to mention the process of using the bending plate included in the lowering kit for the 15-17 models. That is a completely extra step process I was not aware of. Doable but more challenging.
As in the title this will come up; https://motowerk.com/ He is a member on this forum and has been making quality products for many years. I did a search on SW Motech and got zip, found something for a 1000 Versys at Twisted throttle, possibly missed it. Since your product is made by SW Motech, you should be following their instructions. Personally , this is my second Versys, highway peg mounts, lowering footpeg mounts, mirror extenders, lowering link, foot brake extender, flat foot, passenger lowering foot peg mounts. Yes there are cheaper products out there, but I will say nothing superior to his products.I've seen "Speedy's" name mentioned several times. Being a Versys newbie I have to ask, who is he and is he connected w/ SW Motech?
Yeah, I've been to that site. Likely that I'll eventually get his mirror extenders.As in the title this will come up; https://motowerk.com/ He is a member on this forum and has been making quality products for many years.
