21 - 40 of 102 Posts
Good Job
Hi guys,
Finally I finished the blocks for lowering the foot pegs for Versys.
Surprisingly, even for me with inseam of 30.5”, they have improved the comfort of the ride. I designed them specifically for Versys, and they lower the foot pegs straight down by 1.3” (33 mm). They are made of clear anodized aircraft aluminum and come with all hardware and detailed installation instructions. The blocks come as a pair of left and right, with “L” and “R” clearly engraved on them.
When the blocks are installed, the foot pegs will remain perfectly horizontal, so your feet will not slide off them. I also made them quite stout, so they can easily take 400 Lb (200 Kg) each.
You can buy them for $45.00 a pair at my website www.motowerk.com
Now a few words about how I arrived at this final design.
There were some complaints on the forums that the foot pegs were in the way of the driver’s legs when stopping at the intersection. Initially, I designed the blocks to move the foot pegs down and forward to address this issue, however, that cramped the space between the brake lever and the foot peg, and especially between the gear changer and the foot peg. After testing that design, I decided against it, and I designed a new version that you see now in the photos.
Hope you like them,
Speedy
Must be a good feeling to have such a craftmantship skills...
Discussion Starter #22 (Edited)
Hi John,
Glad you are happy. I strive to please :D
If comes to my flatfoot, you are correct. I've just redesigned it a little to allow for the extra clearance. Thanks for giving me your feedback on this.
If comes to the GPS Mount, you are also right. It really is a universal mount that can be used to mount different indicators, gauges, or even an iPod. Yes, somebody has already reported back to me about mounting their iPod ;)
The main plate is 1/8" thick and it's made of the black anodized aircraft aluminum, so it is sturdy enough yet it allows easy drilling of holes.
Thanks everybody for your feedback,
Speedy
OK thanks, maybe a little over kill for a GPS mount. Aircraft instruments panels are normally 2024 T3 to make them easy to drill.
P.S. I have you foot peg lowering blocks and your flatfoot great work.
Hi.
I've instaled yet the Foot Pegs Lowering Kits.
It's very easy to do it and quickly.
How I have the low seat, now with it I have get back the original legs position.
Thanks Speedy.;):thumb:
Yesterday I went out for a very cool (40°F) ride. When I came home there was a package from Speedy…the lowering pegs that I ordered. Today I installed them and spent all afternoon riding (58°F). The lower peg position changed my riding geometry and made the Versys more comfortable to ride. I was a good 1-1/2 hrs into the ride before I got off for a stretch and I had very little back side pain.
Thanks Speedy! :clap:
Was one of the first things I got for the V...The lowered pegs were the bomb...Took about 15 minutes to install unless you count the 20 minutes I spent looking for the cap nut I kicked under the workbench :D
+1 for speedy. I just finished my install of lowering pegs and mirror extenders. Super easy and since my bike came with a brake pedal adjusted way too low from the factory i didn't even need to adjust it. Everything worked great. Now let the hot weather get here.
Thanks speedy, just recieved my three presents today (Mirrror extensions, lowering pegs and kick stand plate), nice touch on the wrapping paper. Waiting for my bike to arrive to install.
Dave
Installed mine today and it went relatively well, even for a mechanical moron like me. I left the gear shifter where it was because I wear hiking boots when I ride and it allows for the extra space. I lowered the brake pedal, though, and had to fool around with the brake light switch to get it operating again. No big problems. Anytime I do a job like this, and the pieces go back together like they're supposed to with no F-bombs, I'm a happy guy.
I wasn't sure if Speedy's 1.3" was enough but, just sitting on the bike, it seems to make a big difference.
Installed the standard footpeg and lowering peg blocks.
First impression is Excellent workmanship and more comfortable with the riding setup now. Less stops and All the way, Boys!
I had also bent the gear change lever and brake lever further out a bit with a pipe wrench. My take is to keep our feet pointed straight and comfortable when performing those vital functions of gear changing and rear braking.
Best Regards:)
Finally got a test ride in with the lowered pegs!! Much much better comfort along with the raised front of seat!! No squirming in 380 miles!!!
Many thanks Speedy!!!
Finally got off my duff and installed peg lowering blocks and mirror extenders. Don't know why I waited so long. Can finally see aft and WAY MORE COMFY riding position.
Thank you Speedy. And a special thanks to Ms. Bea for her patience when I messed up the shipping address.
OK, I guess I will have to be the first to complain about the speedy foot peg lowering kit. My complaint in that soon I will have to replace my foot pegs because the bottoms are dragging a lot in the twisties and my little stubs on the bottom are getting wore down:D. Seriously I am 6'3'' and the insides of my thighs use to hurt after a long ride. Now it all feels great ; it is amazing what a little extra room will do for those long rides. And these are built tuff. I stand on them alot. Am planning on getting the fat foot and also the mirror extenders soon. And I guess the dragging the pegs on the corners is a good thing after you get used to it:D. Although the first time is a little unnerving:eek:. Thanks Speedy for great stuff.
I just got back from my first ride with freshly installed peg lowering kit and mirror extenders. WOW! Now my V really fits me! It's hard to believe how much difference only 1.3" can make in comfort. It even makes the stock seat seem more comfortable. And the wider field-of-view offered by the re-positioned mirrors makes the "cockpit" feel better, too... no more neck contortions trying to look over/around my shoulders makes for a much more relaxed ride.
Lol, just thinking about it now makes me want to go back out for another ride! These are great products, and Kawasaki should buy a bunch and just give them to all Versys owners. Maybe it will help them re-gain some of the goodwill they lost with the Givi bags embarrassment.
Good job Speedy (and the transaction was speedy, too)!
Speedy,
Any plans on making a new shifting lever? I'd rather not lower the pegs, but I would like to be able to shift it without having to point my foot down and in. I'm not nearly as gifted as you when it comes to machining such things, nor do I know of anyone around here that might be.
I just installed my peg blocks and mirror extenders this week and I have to agree, WOW WOW WOW, what a difference. The riding position is so much mroe comfortable, and that is coming from someone who did 1000 miles in 15 hours last fall!
Great job Speedy.
Speedy,
You can adjust the position of the stock shift lever. As a matter of fact, Speedy has the instruction on his website as part of the blocker install instructions. It's pretty easy.
-Alan
Ordered, Delivered and Installed
I ordered the Speedy Peg Lowers on Sunday, they arrived on Wednesday, Installed Wednesday night in 20 minutes or less.
Rode on them today. They look good and provde that more comfortable knee angle I was looking for.
Great looking too. Thanks Speedy!
