Hi guys
Been out of here for a long time, but am still riding the versys and its as good as it was last year!
Before I was complaning a bit because I felt the stock front a bit too high comparing with the rear
Found a match setup both for one and two up the bike which was
rear: preload on the 3th / mid point, damping 4 clicks out
front: preload 4 turns out, damping 3/4 of one turn out
Now on the last revision (18.000km) I asked the mech to lower the front a bit, he lowered about 5mm (1/2 cm). Now when ridding I lost just a tiny bit of front feedback and don´t feel so much confident in turning compared to how it was before. Only thing I did was getting the rear damping one more click out and it felt better, but still would like to fine tune a bit the front,
So how should I correct this, should I add in preload to the front and/or lower the front damping, or should I get the back on higher preload and /or damping ?
thks for any advice, am a bit lost here on how to fine tune this one
Hi Ninogui,
From what little I know, any lowering at the front is to be equally lowered at the rear. This is to keep the bike geometry level.
Lowering the front make the bike stable at straights but feels unstable during turns plus any ground clearance issues. I am not sure how much lower was it to standard before this.
2 ways to look at it. Either
1. Shorten the rear shock with an aftermarket one. ER6 stock comes to mind.
2. Rear Lowering kit as http://motowerk.com/LoweringKit.aspx
Saying this, there might be a need to shorten the sidestand if the bike looks too upright. Checkout http://motowerk.com/Versys.aspx
It would be good to recheck the bike sag again. See if you can readjust the rear sag before spending any money.
Mine is lowered 5mm in front also. Try adding more front compression (1/2 turn) and see how it feels. Then maybe add 1 turn of front preload if needed.
Hi guys
sorry for the late reply, been too busy at work
thks for all your suggestions
reduced 2 clicks on back compression, added 1/4 turn front compression and 1 turn front preload
well.. now it feels exactly close to what it felt before!
added bonus: more straight line stability
un-added bonus: now my knee is closer to grasping the road!
hehehe
Be hard to feel less than a quarter inch; what was the point, If anything it would quicken the steering and lessen straight line stability (by the SLIGHTEST amount)?????
