1 - 18 of 18 Posts
Replacing my Side Doho's that have worked great but worn through the left sole, probably from too many left foot down stops. Make me some recommendations. Must be..
  • comfortable to walk in like sneakers
  • functionally protective
  • must not be water proof or too hot in 30C/90F city temperatures
  • neutral styling, that is not scream I ride a motorcycle
Discussion Starter #2
As a side note I purchased a pair of Doc Martin 8 eyelet boots this past spring to replace the Sidi's however they turned out to be less than ideal due to the following...
  • are not designed to flex forward enough at the ankle to be comfortable on the bike
  • only have a thin layer of leather with no padding over the protruding parts of the ankle bones
  • buckskin leather is quickly worn where it contacts parts of the bike
  • absolutely no breath-ability
Note my main pair of boots is a pair of GoreTex Motorcycle boots I use for more spirited, dedicated or longer rides or riding in cooler or wet weather or with full riding gear. The short boots are to complement these and be used mostly for hot weather riding and commuting in a large city where I need to walk distances off the bike and comfort off the bike is as important as protection. Since wear is spread out I find it does not really cost more to have two pair of boots than a single pair this way.
Several companies make "air" boots that have perforated leather panels. I would rather do that than give up protection.
I like to "Scream" that I ride a motorcycle. That way I can have meaningful "to me" conversations with strangers. :) If I am not on a bike I am wearing some type of motorcycle shirt. There is nothing else I am interested in talking about.
When I meet locals and they see that I ride they point out interesting and amazing roads for me to ride.
I stow them under my pant leg...
They're pretty short, so I haven't had an issue. Also, the zipper on the side means I never have to tie anything unless I need to adjust the fitment.
The sole is a high traction, oil resistant type. I've thoughtlessly done dirty foot stops with absolutely no slipping. And they are wearing much better than my Keens have.
Sent from my LG-H918 using Tapatalk
A number of manufacturers offer riding shoes or riding sneakers. About five years ago, I wanted something I could ride and commute in, and not have to worry about changing when I got to the office. I found these from BMW on Amazon then. They offered a stiff sole and some ankle protection/padding. I've not seen a riding shoe offer armor -- only padding, and even that was not common when I was shopping five years ago. They also have a velcro strap that covers the laces. That said, I haven't tried these shoes on the Versys yet, because I'm not sure how I feel about "losing" the slight height I get from the heel of my TCX Aura boots, but I did find the shoes really comfortable for all-day wear. I'll bet they have an updated version to replace the discontinued style I currently have.
Other riding shoes I like are from TCX. Clearly, I am a fan of Chuck Taylor hi-tops, since that's the style I lean toward. :)
I have the Sketchers Blaine Orson ankle boot, which I bought at Academy but it is usually available on Amazon. Sketchers also has a very similar Dorton Chelsea boot on Amazon (biggest difference I can see is absence of front pull tab, which I never use). These boots have really good grip, which I like since my pea-gravel driveway can be slippery when wet. The boots are also slip-ons with leather on the expanding side gussets just in case you need the protection there (not many boots have this). They are built sturdy, priced nicely, easy to slip on quicly, and look pretty decent with khakis, etc. for corporate casual.
Edit: I did add some cheap gel inserts to my boots, and with those these boots are quite comfortable for either lots of standing or walking.
I have 2 pairs of Alpinestars Joey Riding Shoes that I bought back in 2014 that are still serving me well. 1 pair is regular and the other waterproof.
I tried on a pair of Revit Taylor shoes at a local store the other day. Right out of the box they were equally/more comfy than my Joey's, with much better protection. I will def be getting a pair when my current summer shoes are finito.
https://fortnine.ca/en/revit-taylor-shoes
Bought a pair of those a year ago
They often come on sale at less than $50
They are WP, so they run on the hot side, but it's not unbearable
My 2 cents
LOP
For the past 15 years or so, I’ve been wearing Red Wing Boots during the spring and fall of each riding season.
These Red Wing boots have been very good but I now find them a bit heavier than I would like.
During the summer season, I wear Magnum Stealth Force 6.0 boots.
These are light and very comfortable. If I ever get another pair, I will make sure to get side zipper boots. They are much easier to put on and remove
In the near future, I’m thinking of getting 8-inch tactical sport boots for the spring/fall.
I believe that these should be lighter and probably more comfortable than my Red Wing boots.
I will certainly know when I try them out at the Pre Fair store.
Only specifically designed boots will give the protection you need. I have often ridden in work safety boots, but try standing up in them for any length of time and their lack of instep bracing has them dig into the bottom of your foot.
Beware of shorty boots that are cut low at the back above your heel. They are very difficult to get on and off.
I have some Alpinestar Ridge 2 Air boots for most riding, including dirt roads, and a pair of Forma low boots for trips.
Im like you, I like a light-weight summer boot. I got these Alpinestars and they are perfect. Cooler with some venting. made for motorcycle. I like the size for cooling,when I put my feet up on the highway pegs the air goes up my thick riding jeans. I modified mine with a raised heel and new sole courtesy of my Italian cobbler. This is my system for flat-footing. By the way,a cobbler can resole your old boots!
I have 2 pairs of Bates Bombers and a pair of Bates Tasers. The Tasers are a waterproof short boots that are really too warm in summer heat. The Bombers are better, but look more like a traditional work boot.
Any moto boot you actually wear is better than sneakers. Tall boots may offer a little more protection over your calf and shin, but only if you wear them.
Personally, with my muscle mass, tall moto boots are a no-go unless I spend many hundreds of dollars on them, and they'll likely sit in the closet because they aren't comfortable.
Short or tall, buy the boots you'll actually wear.
1 - 18 of 18 Posts
