1 - 3 of 3 Posts
If money is no object there is always a high end custom shock like the Ohlins or similar. It probably won't provide more travel but I suspect will improve bump absorption and damping.
I found this thread on getting more front suspension travel:
http://www.kawasakiversys.com/forums/showthread.php?t=18133&highlight=longer+springs
Is it possible to get more suspension travel from the rear suspension?
Thanks,
Hugh
Anything is possible if $$ isn't an object. You would need to have a longer stroke shock made and valved accordingly. There might be other issues that would come along with it such as the possibility of a chain idler to keep the chain slack at a minimum when the shock is at it's longest part of the travel.
Simply making a ride height adjuster would only suffice for making the bike sit taller and gaining ground clearance, but it wouldn't add to suspension travel.
1 - 3 of 3 Posts
