1 - 14 of 14 Posts
At this moment it sits with a TAd over 400 miles. I assume by the time I am able to get free to run up to WV Ill have maybe another 150-200 miles on it.
Continued interstate speed operation for 3 hours on the interstate before I hit the curvy WV mountain roads has me concerned.
Is it safe? Im assuming Ill be running in the 4500-5500 range until I hit the two lane then more relaxed in the 4000-4500 range.
To Clarify I Know Its zero issue for the bike in general, Just with so little miles on it would you consider it a safe thing to do?
If you already have 400 miles on it, the engine is broken in. If it were me I would change the oil and filter BEFORE you go. Ride it like you stole it. Don't pay too much mind to the factory break-in recommendations. They are NOT realistic and very restrictive. IF anything, vary your speeds and RPM's when possible.
...If it were me I would change the oil and filter BEFORE you go. ...& ... IF anything, vary your speeds and RPM's when possible.
+1
When varying speeds, make sure you let the engine "back down" using engine compression. That way you will pull a vacuum on the piston rings, helping them to seat better.
Have fun!:grin2:
+1
Have fun!:grin2:
I agree with this in general, hence what has me worried, I wont really bei varying speed much for 3 hours straight. I changed the oil 80 miles ago, still think its safe or should change it again (would end up having about 280-300 miles on it again before changing oil) or if I wait til I got back it would have about 1000 miles on the oil ,
Sorry I was reading your signature and thought how much sense it made..People think im nuts for riding in cold weather I can only imagine where you are how cold it gets!
I wouldn't change the oil again until another 3000 + miles.
Depending on traffic, you could think about just riding in the right lane, check for traffic behind you, and back er down from 70 mph down to 45 mph once every 30 minutes or so. Failing that, you could exit the interstate at 45 minute intervals, and then get back on.
When I got my 2014 I rode it all over the place the first weekend I had it, I racked up 600 miles. Had the bike for service next Monday, because the next Saturday I was leaving on a trip to Deals Gap, it was 5500 miles round trip.
do you have gas in the tank? is there air in the tires? if so ya it should make it =p
Reactions: my2wheels
Read this:
thanx
It's what I have done on all THREE of my Versys 650s, on the ride home from picking them up at the dealer.
I would change oil & filter again before your trip. When you return, I'd change it AGAIN, then put synthetic in (I use Mobil1 automobile 15w-50, and HAVE for close to 100,000 miles!).
I totally agree with all the advice given, especially what trialsguy said about finding ways to vary your speed. If there are any County Roads that parallel your route you could try one of those for a short stint. Any way to lessen your worry can only make the ride better.
There are the manual break-in style and the motoman break-in style. Since I do not see any indication that any of these engines are breaking down, burning oil and blowing up, then I think that neither of them matter. If you intend to keep this engine until it reaches 300,000 miles, then you may have a significantly different interpretation. As I see it, these engines are robust and the "break-in method" simply does not matter. You can read pages and pages of anecdotal data on break-in, but that is not real data.
I would not worry too much about riding a Versys on the interstate and thereby damaging its engine. According to the manual there is some risk, but according to reality, there is little risk.
Reactions: canit
1 - 14 of 14 Posts
