1 - 20 of 34 Posts
Discussion Starter · #2 ·
I just had an idea...I think I'll tie the marker lights in with the front turn signals...
Discussion Starter · #5 ·
Do both the high and low beams use H7's?
The factory low beam cutoff angles are horrible and don't give much distance.
Yes, they are both H7. I was thinking about removing that center cover in the low beam to see what effect that has....
Slightly different take...
Right, figured I'd drop some photos of my frontals.:eek:
Hooligan, looking at that little plastic bit, if you figure out how it comes out and it does something good, let us know for sure. I have adjusted mine up quite alot, but the beam still drops off so immediately, a bit unnerving when rolling up the highway through the forest. The high beams though, wow, retina searing, killers!!! Oh, before I forget, my side marker lights are just some cheapie Pilot "Xenon Lightning Whites". A fancy name for "normal bulbs we dipped in blue paint"....Oh, wait, says here they are "natural color glass", Ok. My H7's are Sylvania Silverstars. I really love these bulbs and have used them on every vehicle I've owned since they were introduced. Great color temp and awesome output.
Fukken cheers,
Erik!!!
Here's mine with amber LED front marker lights... I also upgraded to Osram Hyper H7 clear 65 watt bulb (bigger H9 burner on H7 base) from their high-wattage rally and professional offroad bulb line, and they're absolutely awesome! They offer 2100 lumens and a 500 hour life, compared to:
1780 lumens, 340 hours for the Osram Night Breaker with slight blue tint.
1750 lumens, 350 hours for the Osram Silverstar (not Sylvania) also with slight blue tint.
I got them from http://www.suvlights.com/product_info.php?products_id=164 for $21 each + $8 shipping.
Hooligan,
I was thinking of doing the same thing by removing the little cone in the center that blocks the light from the end of the bulb.
Is the high beam a different wattage than the low beam?
High and low beams are both H7 55 watt. That cone is needed for the low beam, and would be very hard to remove... The Osram Hyper 65 watt H7 does a great job. Very bright and white light.
...I also upgraded to Osram Hyper H7 clear 65 watt bulb (bigger H9 burner on H7 base) from their high-wattage rally and professional offroad bulb line, and they're absolutely awesome!...
Nice to hear! I ordered the same ones and expect to get them next week. The stock low beam is terrible IMHO.
Kool... You'll get them pretty quick, and won't be disappointed. H7 bulbs are pretty small and have to be pulled out of base connector to be replaced, and they're in tight. Be careful not to touch the glass.
My Versys came with the headlight adjusted too low and to the left, as many others are as well.
I was going to adjust mine, but I knew I wanted to upgrade the lights so I figured I would do it at the same time.
I am also going to turn my front turn signals into running lights, and make the daytime lights in the headlight assembly blink with the signals when I take it apart to install the lights.
Well,
I put in the Silverstar Ultras, took out the little cone(VERY EASY with just two little screws to remove) and then proceeded to wash the wife's new Armada....It's now 10 and I've got to get to bed. I'll have to try it out tomorrow night and let you guys know if it helped.......
William
...I'll have to try it out tomorrow night and let you guys know if it helped....
Oh come on now, just roll it out and shine the lights to see what it looks like. You gonna make us wait until tomorrow night? :(
Yeah, I had a quick look at the bulb shield and it's obviousy very easy to remove on the Versys...
My Osram Hyper 65 watt bulbs are already very bright and not legal on public roads. Removing the shield would make it even harder to aim it high enough without concern about blinding oncoming traffic.
I found some information about the purpose of the bulb shield:
"The bulb shield generally functions to prevent light from striking areas of the headlamp reflector that are not optically active so that stray reflections (glare light) is prevented from being directed towards unintended or dark areas of the prescribed beam pattern. Bulb shields typically include a cup portion that is disposed generally in front of the headlamp bulb, and a portion that extends from the cup portion and mounts to the reflector or some other proximate structure. The cup portion of the bulb shield is usually relatively sharply concave, thereby blocking light from the bulb that has not first struck an optically active portion of the reflector. The bulb shield, (when employed) provides a shuttering or masking effect that prevents unwanted visible light rays from reaching unintended (decorative) reflective surfaces and being reflected in an uncontrolled manner ("Glare"). The overall distribution of visible light from a headlamp is heavily prescribed by NHTSA (National Highway Traffic Safety Administration) in FMVSS 108 and it is often impossible to meet these requirements without a carefully designed bulb shield in place."
Well, I tested it this morning and the combination of removing of the shield, Silverstar Ultras, and turning the vertical adjustment screw 1 1/2 turns clockwise DEFINITELY works much better!!:thumb: I can see with low beams in very low light areas! No one in the opposite direction of traffic flashed me either......:cheers:
Had the same issue, I adjusted mine the other night and it made a HUGE improvement, I actually think the stock lights are pretty decent, once adjusted. :)
...H7 bulbs are pretty small and have to be pulled out of base connector to be replaced, and they're in tight...
arghhh. I was going to put my new bulbs in today and thought they sent me the wrong ones. The connector wouldn't fit on the bulb. I guess I have to remove the big black plastic piece off the factory bulb and put it on the new bulb?
1 - 20 of 34 Posts
