1 - 3 of 3 Posts
Hello, all:
I am a new member, having been out of motorcycling the past 20 years. I am 56 now. I am picking up a new 2015 Versys 1000LT (Burnt Orange) in two weeks, and I plan to have either the dealer or a motorcycle shop install the following:
1. Denali D2 Dual Intensity Lights. Installed just under the fairing. Low beams will go on automatically with the ignition and the higher intensity lights will go on with the high beam switch.
2. Denali DM Lights. These lights will go on with the ignition and stay on.
3. Admore Lighting with Smart Brake Technology.
4. Denali Duo Tone Soundbomb.
A lot has changed in 20 years, and I want to use all of the technology available to make myself more noticeable and see better at night. In addition, I plan to take a refresher MSF course.
Thoughts? Thank you.
On the Versys 1000 i would go with the Denali Split Sound Bomb and the brackets to mount it that you can get at Twisted Throttle. I tried to mount a Stebel multiple times finally had to separate the resonator from the compressor to mount. Theres just not much room to mount a larger horn on the Versys 1000. Got it mounted but was a big pain.......http://www.kawasakiversys.com/forums/9-technical-discussion/124569-separated-stebel-horn-mount.html
I have the Large Admore Light Bar mounted on the license plate holder and have the Admore Light Kit in my Givi E-55 Topcase. Admore is a great product with fantastic customer service. In the photo below i didn't have the top case lights wired in yet.
P1010446 by weljo2001, on Flickr
1 - 3 of 3 Posts
