Have you tried searching for your inspection regulations? It would give you the items that the inspector has to look for. In my state the signals need to have DOT on the lenses and be a certain distance from the head/tail light. Many aftermarket signal lights are labeled as offroad only and don't have the DOT markings. The same for led headlights. Another thing is that fog lights have to be switched to turn off when you turn on the high beam.
Most regulations are way behind current technology so some inspectors will ignore common modifications others will go by the letter of the law. Just because everyone does a certain modification doesn't mean it is legal.
It sounds like you are doing everything you can to have a safe and legal bike. Good luck
