Hi,
I have in plan to go LED lights on my 2018 V650 (headlights and turn signals).
Now for headlights I know how to solve that problem.
But for LED turn signals I have questions? (maibe first question will be stupid, but I don't have any spare turn signal to dismantle them to see how it look inside)
1.
All aftermarket LED turn signals which I find for my V650 look like this (I mean on this left part screw + nut):
Now this screw with nut, does that also exist in OEM V650 turn signals, but there are plastic which are around that (and you use this screw and nut to tight OEM plastic to aftermarket turn signal), or I need to buy something also aftermarket so I can add this type of turn signals
I hope that you understand what i wish to say.
I can buy on aliexpress turn signals for V650 whish are almost 100% same (by picture and by some video which I found on youtube), but I will have problem on the technical inspection of the motorcycle, because the turn lights are not homologated, and I won't be able to register a motorcycle . So I am forced to buy homologated turn signals (picture which I add are holomogated LED turn signal)
2.
I see that if I wish to add LED blinkers that i need to add relay or resistor. What is better? 1 relay or 1 resistor for each turn signal?
1.
2.
