1 - 18 of 18 Posts
Planning on getting a new 2016/2017 Versys soon. Are there any known issues with these bikes or concerns to look for? Most of what I have read or viewed online has given good news.
I had to replace the rear brake pads on my '15 650 at about 12K miles. My '08 (at 66K miles) is STILL on the originals...!
That's just regular maintenance. Could this be the most reliable bike on the market for the last ten years?
Multiple Posts on Rear Brake MK-3
I can tell you it isn't, my 2015 rear is making noise at 11000 KM, my 07 had original pads when I sold it this year with 30,000 KM on it. I think I may be paying a visit to my dealer before the warranty runs out.
Rear Brake / Dealer / Head Machanic Inquiry
I have called about the rear brake, today was a off day for the head mechanic, plan is to call tomorrow and the owner of the Dealership will also inquire today for me. One question was related to the ABS which really shouldn't have a effect, however I will post what I find.
One thing I like about this dealership is the mechanic says it like it is, as a example, I had the first service done by them, came to something like $130.
I was down weeks later picking up some special parts/ tools for doing my own servicing, stopped into the service department and talked to the head mechanic, I asked about synthetic oil, he said part of his training from Kawi, was you could run synthetic oil from the very first oil change, that information was a total surprise. A month later I returned 4 liters of Kawi mineral oil and got my money back. I am now a happy Mobile1 15/50 synthetic oil user, on my 3rd oil change!!
Personally - I do NOT accept that the rear pads being worn-out by 12K miles is "regular maintenance", particularly as I have had two Gen 1s that had the OEM rear pads for MUCH longer.
Dealer/ Head Mechanic / Rear Brake
I talked to the head mechanic, who converses with Kawasaki all the time.
#1 The rubber boot on the front , make sure it is in the proper place, check the manual it mentions a good brake grease be used , refer to the manual for instructions, as you should know, you do not want any lube of any kind on the rotor or brake pads. I found the rubber boot on my 2015 pushed/ compressed to the maximum, I possibly cause that although I think it came that way, you will see a groove were the front of the boot is to sit in.
#2 The second and most important thing, which I thought of before, was the fluid level, it needs to be at or below maximum, otherwise when it heats up, it has no place to expand, hence the dragging rear brake.
As to the dealership, they haven't had any reports of rear brake problems and this is a excellent dealership. I don't want to mention the name here as it would be unfair to the others. If you live in Central Ontario this is a good one.
Riding home from work this morning my clutch cable froze up....had to pump it several times to get it to work. About 13 degrees F and interstate speeds.
I think that may be due to using oil incompatible with the tempature. It's an oil immersed clutch.
As for rear brake pads wearing out at 12K miles. I've not had that issue. I would look for other causes than the pad material though such as resting your foot on the brake lever, the position of which is adjustable, or crud on the brake caliper cylinder sidewall which might prevent it from retracting fully. Check to see if the rear wheel is freewheeling without resistance after applying rear brakes. The stock pads are semi metallic and common across most new bikes. I normally get 25,000 km or more out of my front pads and have yet to need to replace rear pads.
I'm on my second Versys with no issues to report. One thing to be aware of though, as with any bike that does not have a kickstand, is you will need to purchase spools and a rear pit stand for cleaning and maintenance.
I had front pads and rotors shot by 13k miles on my 1000. Probably the same supplier. New rotors replaced UW have gone 16k miles with no issue at this point, but pads were replaced again at 26k. Rear pads replaced at 20k miles. Oddly, I use the rear a lot more.
Replaced both ends with EBC HH. Yet to be seen how they hold up.
I think that may be due to using oil incompatible with the tempature. It's an oil immersed clutch....
The issue was w/ his cable.
...As for rear brake pads wearing out at 12K miles. I've not had that issue. I would look for other causes than the pad material though such as resting your foot on the brake lever, the position of which is adjustable, or crud on the brake caliper cylinder sidewall which might prevent it from retracting fully. Check to see if the rear wheel is freewheeling without resistance after applying rear brakes. The stock pads are semi metallic and common across most new bikes. I normally get 25,000 km or more out of my front pads and have yet to need to replace rear pads....
As I mentioned - on my '08 I have yet to replace the OEM rear pads (NOW at 67,xxx miles!), so it would appear that I'm NOT doing anything differently to account for the early wear.
I highly recommend replacing your cable operated clutch with a Magura hydraulic clutch system. It includes everything you need to convert your cable operated clutch to a hydraulic clutch for about $200. The clutch is much lighter operating and the feel is improved. I replaced mine 8,000 miles ago and have not had to do any adjustments or maintenance to my clutch. Here is a link with detailed information:
http://www.kawasakiversys.com/forums/9-technical-discussion/106698-hydraulic-clutch-puzzler.html#post1213073
1 - 18 of 18 Posts
