1 - 19 of 19 Posts
On my first post, I mentioned a recent trip I made from Albuquerque, NM, to Flagstaff, AZ, round trip. I was following a rather ambitious fellow on his BMW GS1200 Adventure bike. He likes to move along pretty quickly, so we averaged, for the most part, about 85 mph plus for the whole trip. There were considerable cross winds, as well as interstate, trucks, and the like to deal with. Not my favorite kind of riding. Anyway, on that trip, my gas mileage averaged between 43 and 46 mpg.
Today I took a ride with another friend of mine, to Jemez Springs, NM, for breakfast. We rode at a more sensible, and desirable pace of 65 to 75 mph for the most part. It wasn't a long ride, but long enough to check my gas mileage at my typical riding speeds.
When I filled the tank after returning, I used the same method as before: bike was level as possible, and filled up to the bottom of the filler tube. The odometer read 119.8 miles, and I used 2.056 gallons. That works out to a little over 58 mpg. That would give me about 290 miles per tank of gas, if I rode till she ran out. Pretty impressive. Is this typical?
Whenever you achieve ludicris speed fuel consumption will drop ....I think the grin is causing too much wind resistance
45 mpg when having fun
55 when being good
Well, you're right about that. Actually, I don't think I phrased my question correctly: Is 58 mpg at normal highway speeds typical?
I guess that's the source of my confusion. I've seen guys on this forum claim everything from mid 40's to 60mpg, so I'm kinda wondering what most people are getting. To tell you the truth, even 45 mpg is fine. With a 5 gallon tank, I'm pretty assured at getting over 200 miles per tankful. Even though I stop much more often than that (rest stops, picture taking, etc.) it's nice to know I have more control over where and when I have to get gas.
There are so many variables that you will see big differences from person to person. A person that weighs 250 vs 150 is a extra 100pds. On a sub 500pd bike that is a 20% increase in weight. Plus how hard you accelerate, or how fast you ride.
58 miles per US gallon is excellent. I get about the same at such constant moderate speeds, as does fasteddiecoppeman... Are you absolutely sure you refilled it to exactly as full as it was before? A mere 2.056 US gallons and only 119.8 miles is a very small quantity to reliably calculate fuel mileage with any appreciable level of accuracy.
Never run it until you're completely out of gasoline. Letting the fuel pump run dry and ingest any air can be highly detrimental to it and greatly reduce its service life.
Just my two cents. Tire pressure may come into play for max MPG. With the stock tires still on, I run a little less air and enjoy the smooth ride. I think that alone could be + or- 8 MPG. :thumb:
Of course I can't be absolutely sure about anything. I can only get things as close as eyeballing can get them. But I tried to duplicate the conditions as much as I could. And you're right, only a couple of gallons doesn't establish anything concrete.
I'm certain once the season progresses, I'll be able to get a better idea of what I'm dealing with. I usually take an average of what I get over the course of an entire trip, because so many things affect gas mileage. But being so new to this bike, I wanted to get the opinions of those who have more experience with it.
My '08 in Phoenix gets pretty much high-50s, and my '09 in BC, for the last two fills, has averaged 57 to 58 MPG/US.
I MIGHT 'push' the speed limit a bit, but I try not to "fracture" it!
:goodidea:
I've heard reports that it was capable of up to 65MPG if cruising at around 80kph.
My personal best was 63MPG, riding about 40% back roads (70 to 90 kph) and the rest of 60% was my normal city commute. I get 55MPG on city commute, typical.
There are lots of friction points in play when the bike is moving, beyond just the tires: wheel bearings, chain and sprockets, and brake pads on discs, for example. These all can have an impact on fuel efficiency, as well as the general state of tune of the engine. Road surface, wind, ambient temperature and riding style are other factors. It's probably more meaningful to establish a baseline for your own machine, so that if you find a dropoff in fuel economy you can search for the reasons why. In general, the 650 is a pretty fuel-efficient engine (judging by what people are reporting on the forums), but not as frugal as BMW's 800cc engine, and way off the new Honda 700cc parallel twin.
I keep fuel use stats for business. I fill up every time and track where I fill up, miles since last fill up, gallons to fill, cost per gallon, total cost, MPG and cost per mile. The location of fill up is the coolest thing to track...fun to remember the places I've gone.
With all that data over 18,000 miles, my Versys has averaged low 50's. I've managed high 50's on a couple tanks when traveling with friends who prefer a less enthusiastic pace. On the occasions when I've had to hit slab for long distances, fuel economy drops significantly, down to the mid 40's.
For comparison, over 71,000 miles, my ST1300 has averaged low 40's, rarely going below 40 (typically when it's very cold) and occasionally going into the high 40's (mostly in places where there is no alcohol added to the gasoline).
With both bikes, I can confidently conclude that enthusiasm with your right hand hurts fuel economy.
YMMV (Hey...that's funny!)
On the 2009 I recently purchased with 2,550 miles on the clock I've filled up three times... I realize there will be a slight variation on how "full" I fill the tank, but that will average out...
1st time: 54 MPG
2nd time: 50 MPG
3rd time: 52.5 MPG
Combination of traffic lights through the town & cruising about 60-65 MPH
on my 20 mile commute to work.
I like this bike more every time I ride it. Just installed the v46 Givi topcase & the Givi v35 sidecases are at my feet in the living room. Hopefully I can get them installed this weekend....
Ride safe everyone,
gary
Best mpg I've ever attained on the Versys is 61 mpg. I think 58 mpg at 65 mph is about what I get every time. Worst I've ever had was loaded down, and into a headwind: 48 mpg.
Fuelly.com is a free website where you can track mileage of all your vehicles, and also get a comparison to see yours vice others. Last time I looked, there were 38 or so Kawasaki Versys on there. You can put your fillup in when you get home (what I do) or enter it right on your smartphone at the station. Very handy. (I have no affiliation with this website, just an end-user.)
Well, I guess we nailed that one down. Anywhere from 45 mpg to 65 mpg. I just stop at least every 200 miles and try not to worry about it.
1 - 19 of 19 Posts
